REDARC releases the BCDC Alpha100 R battery manager - Caravan World Australia
REDARC has launched its BCDC Alpha100 R, the most powerful model in the BCDC range, engineered for serious users running high-capacity battery systems.
Building on the success of the Alpha50 R, the new 100A version delivers lightning-fast, efficient charging to support demanding off-grid power management, whether it’s a complex caravan setup, an RV or a power-hungry 4x4 rig.
REDARC integration: Smart charging, monitoring and control
The BCDC Alpha100 R delivers the performance and system visibility required to stay powered and in control, combining auxiliary battery charging, start battery recovery, RedVision connectivity and an integrated Smart Battery Monitor in a single, compact in-cabin unit.
This release completes the REDARC BCDC Alpha lineup, offering a full suite of high-performance charging options tailored to modern off-grid power management needs.
REDARC’s global president, Peter Favilla, said: “With the BCDC Alpha100 R, we’re completing the Alpha lineup and giving high-demand users faster charging, more control and expanded functionality.
Pull up at camp and easily check your power levels with RedVision connectivityPull up at camp and easily check your power levels with RedVision connectivity
“It’s essentially a mini-Manager for those who don’t need mains power, offering advanced control in a form factor that’s just a fraction of the size of the Manager Alpha.”
The BCDC Alpha100 R charger automatically adapts to your battery’s needs in real time, maximising efficiency and extending battery life. When the charge rate is set below maximum, the Alpha100 R redirects unused power to run your system’s loads directly, rather than drawing from your battery.
That means more stored energy when you need it most, allowing your fridge, lights and electronics to run even longer. Integrated with REDARC’s RedVision system, users can monitor key metrics such as state of charge, charge performance and time remaining from their mobile device.
The REDARC BCDC Alpha100 R unitThe REDARC BCDC Alpha100 R unit
For more information about the BCDC Alpha100 R and the complete BCDC range, visit the REDARC Electronics website.
REDARC’s new BCDC Alpha R DC Battery Manager
REDARC: Leading the charge in off-grid power
Coming soon: REDARC Lithium Adventure Batteries
