Coming soon: REDARC Lithium Adventure Batteries - Caravan World Australia
Designed with off-grid touring in mind, REDARC Electronics’ new Lithium Adventure Batteries (REDLAB) are made to deliver stable, long-lasting power in Australia’s varied and demanding environments.
With a robust construction, reliable performance in extreme conditions and seamless pairing with REDARC charging systems, the 12V 100Ah, 200Ah and 300Ah lithium LiFePO4 REDLAB units are aimed at caravanners and four-wheel drivers who love heading off the beaten track to explore Australia’s beautiful but remote areas.
Power to spare
Caravanning setups are getting more power hungry with each passing year, so being able to run bigger setups with fewer batteries is enticing. The REDLAB batteries offer 100 per cent usable capacity — meaning you aren’t limited by the reserve — as well as ultra-high charge and discharge rates and support for powerful inverters and chargers, meaning these new units deliver plenty of power without the bulk and weight of lots of batteries. The batteries offer more than 6000 charge cycles and include a state of charge display, so you always know how much power you have.
Built to last
Like all of REDARC’s high-quality gear, the REDLAB range has been built to withstand Australia’s toughest terrains. The unit construction has an IP67 rating for water and dust protection as well as extreme vibration resistance, meaning they can handle rough corrugations like you’ll find on the Gibb River Road. They’ve also been engineered to handle Australia’s diverse climates, from the hot outback to freezing alpine mornings and include a built-in heater for below-zero charging.
A smart solution
The REDLAB batteries are designed to work seamlessly with REDARC’s BCDC and Manager30 chargers to offer a simple and reliable all-in-one power system that takes out the guesswork for users.
For peace of mind when on the road (or off it), the REDLAB batteries have been built to the latest standards certifications and include cutting-edge safety feature and a built-in isolation switch, making them safe to install, transport and ready for off-grid adventures.
Find out more
To learn more about REDARC’s new Lithium Adventure Batteries, head here.
Installing a REDARC Tow-Pro Elite Brake Controller
Power up with REDARC's Manager Alpha range and Smart Battery Monitor
