Caravan review: Sunland Caravans 18'6 offroad van
Written by: John Ford
Under new ownership, the legendary Sunland brand is in good hands. We reviewed its latest compact van, retailing at under $100k and packed with all the offroad essentials.
Okay, first up, a confession. We bogged the review van in deep sand on Yarun/Bribie Island, Qld. In my defence, it was a first for me when reviewing a van, and the track had been badly chewed up with 400mm soft sand. Happily, Jason Wylie, the new owner of Sunland Caravans, could see the funny side, and we had a comfortable van to sleep in and a freezer full of fish in my car to keep us nourished. Who would get the double bed in the van might have been an issue, but we finally got moving again, so that was a problem we didn’t have to face.
We have headlined Sunland Caravans as legendary, and that’s not an overstatement. The original owner, Roy Wyss, liked to do things differently and became something of a legend in the caravan industry. Roy was an innovator who was fearless in stepping out of the customary way of building a van made to tackle the worst roads the Australian outback can dish up. Roy led Sunland as an early adopter of composite construction and the first and still the only manufacturer with an aluminium chassis.
This 18ft 6in model breaks new ground for Sunland
When Jason Wylie heard that Roy was considering retiring after more than 20 years of building vans, he made an offer Roy couldn’t refuse, and a new chapter began. As part of the deal, Roy’s son, Tarot, stays on as general manager at Sunland.
Jason brings his years of experience in manufacturing for the building industry and expertise in smart caravan manufacture to the table. He started Design RV and made it a success over the past three years. Following the sale of Design RV, he was looking for an upper-echelon offroad brand to complement his new project — the imported X-Series — and he decided that Sunland was the perfect fit.
Not one to let the grass grow under his feet, Jason purchased a new factory to the east of Caboolture, Qld, and moved the business and the 52 employees in the first couple of months of ownership. Production is already streamlined, and strict quality control procedures are in place. As part of Sunland’s rebranding, this compact single-axle van seen here joins the lineup, and as a sub $100k offer, orders are already flowing in.
The build
While there have been previous single-axle vans in the range over the years, they have been the exception, so this 18ft 6in breaks relatively new ground, with its $98,000 selling price as a deliberate ploy to announce a new direction for the brand. And while it might be missing some of the current array of high-end electrics, it’s a capable offroader with rugged Sunland DNA.
The front, roof and rear walls are a single-piece composite construction
At the base of the build is a rivetted and professionally engineered aluminium chassis welded to a substantial steel A-frame. A 20-year chassis warranty should convince any sceptics about the durability of the alloy chassis. The body is formed from locally sourced Link Composite panels of fibreglass skins over XPG foam that are mated together into a unit that is both immensely strong and has high thermal insulation. The front, roof and rear walls are a single-piece construction to ensure weather resistance and that the walls, floor, and roof bond together in an immensely robust unit.
Chassis detail
Underneath is a Cruisemaster trailing arm suspension rated at 3000kg and customised to be 50mm narrower than standard to suit a narrower-than-usual body designed for tight tracks. Upholstery and CNC-cut furniture are made in-house, and his commitment to fine detail has been carried over to the new processes.
Over the past few years, we have seen single-axle vans increase in length due to heavy-capacity 3000kg suspension setups. By adding length, there’s more room at less cost both in initial outlay and in maintenance of things like tyres and wheel bearings. Such a setup needs careful design to allow proper weight distribution. You also need to upgrade tyre and wheel load ratings, and higher-rated tyres have stiffer sidewalls and might deliver a harsher ride. The new Sunland seems a sensible compromise with a 2800kg maximum weight while still bringing 779kg of payload.
For a refresher on caravan weights, check out this feature by Malcolm Street.
The exterior
Smooth fibreglass walls have a neat look, and a lower Raptor style covering in matt black breaks up the large area of white. A Cruisemaster DO35 offroad hitch and holders for twin 8.5kg gas bottles are at the drawbar. A full-width alloy toolbox includes a passenger-side slide-out for a fridge and tie-downs up top for firewood. Further back is a full-width tunnel boot, 12V and TV access points and a manual twin-tread step.
The rear is neat and simple because the spare is located under the van and forward of the wheels to keep the correct weight balance. A hatch at the back of the van opens to inspect the shower plumbing, and another houses the taps and pump for the water supply.
The shower plumbing in a rear hatch
Liveability
The benefits of a more extended single-axle van are apparent when you step aboard because, for a single-axle design, there is a lot of living space, including the all-important north–south bed and a usable ensuite. With the entryway behind the wheel arch, the bed is at the front and away from the door for maximum privacy, which is essential to some owners. The ensuite is to the right as you enter, and it’s a traditional design with a Thetford cassette toilet, a descent-size vanity with a floor-mounted top-load washing machine and a roomy shower. White furniture and big windows lend a bright, well-ventilated impression, and a clear Perspex shower door adds to the feeling of space. Storage is excellent with deep overhead cupboards and a set of drawers down low.
The bright bathroom with washing machine is surprisingly spacious
I like the light, cool-toned colours and large windows in the living space for the upbeat vibe. The black upholstery at the cafe dinette matches a black fridge further back and is neatly finished with cushions that give comfortable support.
A basic kitchen bench runs along the passenger side and includes a gas cooktop, a black sink with a matching mixer and draining board and about 500mm of preparation space. For a single-axle van, it’s a good compromise of space, and I imagine most buyers will explore options for outside cooking.
Access to the bed is good all around, and like most modern vans, there are storage nooks, reading lights, and charging points. A leather magazine holder is a bonus. Storage is generous for this size van, and that’s important for long-term travel. In addition to the high cupboards and the bench, there’s room under the lounges, and the whole space under the bed is open.
With batteries gone there is plenty of storage under the bed
Roughing it
With two 200W solar panels and a pair of 150Ah of lithium power, there’s enough onboard power to keep the 12V fridge, lights and water pump operating so couples can spend time off-grid without worrying if the drinks will stay cold. The batteries are KIJO, so they are as good as you will get, and the rest of the electronics are all quality equipment and are installed professionally in-house. Batteries are chassis mounted, and you can check the state of charge on a REDARC RedVision screen in an overhead cupboard in the kitchen. I noted a wiring diagram there, too, and you might think that was a strange thing to mention, but I have to tell you it’s rare to find in a caravan, so all credit to the Sunland team.
For more info on understanding and calculating your power setup, check out this feature by John Hughes: 'Prepare to go off-grid: A guide to power mananagement'
Towability
Let’s set aside the beaching of the Toyota tow vehicle for a minute and report on how things went before coming to an ignominious halt. It felt great out on the highway and regional roads behind the LandCruiser, and we easily made our way through urban streets and tight roundabouts to Bribie Island National Park and Recreation Area. The van was almost empty, and it had a naturally well-balanced feeling. It handled well without undue bounce or pitch over the rough ground in the park. The 2021kg tare weight and 2800kg ATM will be a bonus for easy towing with a range of twin cab utes, and something like a Prado or Pajero should be a good match.
Exploring Queensland’s beautiful Bribie Island National Park
The bottom line
This single-axle van is aimed at couples who want a capable, properly engineered offroader with a stable reputation. It deserves a place on this sort of buyer’s shortlist.
An entry-level Sunland makes sense for the new brand owner looking to make a splash in the local caravan pool. Jason brings new ideas around production to the company, and his plans to streamline production include ever-increasing quality improvements. This latest model should earn a good share of attention because the sub $100k market is prime territory for new buyers. Sales are already flowing in from buyers interested in the Sunland ideal without the budget for the more traditional versions.
  • It's a lightweight caravan so it's suitable for a good mix of tow vehicles
  • Roomy single-axle layout
  • Solidly engineered aluminium chassis and composite body
  • Under $100k threshold
  • Some will opt for more battery power
SUNLAND 18'6 RATINGS
Sits under $100k, where the current market searches
Lightweight and well-balanced for a great towing experience
Couples will appreciate the extra room and offroad ability
The new direction for Sunland doesn’t compromise quality
A single-axle van with ample room for a couple
Enough solar and battery to run what you need in suitable weather
A 20-year chassis warranty and a commitment to customer service
The only major manufacturer with an aluminium chassis and one of the first with composite body construction
Sunlands exude an aura of the outback spirit
SUNLAND 18'6 SPECS
Body length 5.6m (18ft 6in)
Overall length 7.8 m (25ft 6in)
Width  2.48m (8ft 2in)
Height  3.08 m (10ft 1in
Tare  2021kg
ATM  2800kg
Payload  779kg (calculated)
Ball weight at tare 227kg
Ball to tare ratio 11.2% (calculated)
Frame  Composite panel
Cladding  Fibreglass
Chassis  Aluminium C-section with 150mm x 50mm steel A-frame
Suspension  Cruisemaster XT trailing arm 3T
Coupling  Cruisemaster DO35
Brakes  12in drum
Wheels  16in alloy
Water  190L freshwater, 60L grey water
Battery  2 x 150Ah KIJO lithium
Solar  2 x 200W
Air-conditioner Sanjo
Gas  2 x 8.5kg
Sway control N/A
Cooking  Three-burner gas cooktop
Microwave  Flatbed
Fridge  190L compressor
Bathroom  Full-width ensuite with shower and Thetford cassette toilet
Washing machine Top load
Hot water Instant gas
Sunland 18'6 price from $98,990
N/A
Sunland 18'6 price as seen $98,990
Sunland Caravans
59 Alta Road
Caboolture Qld 4510
P: 07 5499 2250
E: sales@sunlandcaravans.com.au
If you want to learn the latest caravan news, find the most innovative new caravans and camping gear or get inspired to plan your next road trip adventure to some of Australia's best getaway destinations, caravan parks and off-grid camps, subscribe to our weekly newsletter. We promise to send you only the best content.
Caravan review: Sunland Patriot SEL-X
Tow Car of the Year? | Best tow vehicles at COTY 2024
Tips from the experts: How to drive on corrugations and rough dirt roads
