Years of design and research went go into this deep-cycle lithium battery
Power your adventures with the iTECH120X lithium battery
Having a reliable power source is essential when travelling with your caravan or camper trailer. And to help keep your adventures going iTechworld has presented a lithium deep-cycle battery: the iTECH120X lithium battery.
The X Range from iTechworld offers features and capabilities over its conventional batteries that enhance how you use your battery, an IP67 waterproof rating and advanced Battery Management System, as well as a full five-year Australian warranty.
The X Range from iTechworld offers features and capabilities over its conventional batteries that enhance how you use your battery, an IP67 waterproof rating and an advanced Battery Management System, as well as a full five-year Australian warranty.
This bit of gear represents more than a decade of Australian research and development by iTechworld’s expert engineers, all of which have helped make the iTECH120X is one of the most stable lithium batteries on the market.
Designed with simplicity, high performance and ease of use in mind, the iTECH120X lithium battery is an easy drop-in replacement that will fit seamlessly into existing lead-acid or AGM battery systems without the need for any rewiring or modifications.
Featuring 105Ah usable capacity and a maximum discharge rate of 270A, the iTECH120X lithium battery is ideal for providing plenty of power to all kinds of devices over long periods and for off-grid use. When paired with an inverter, it allows you to run induction cooktops, CPAP units and even coffee machines, making it an appealing choice for weekend warriors and long-haul van adventurers alike.
Another standout feature is that this battery can be connected to an unlimited number of other iTECH120Xs in parallel simultaneously, meaning users have the flexibility to create an energy solution that perfectly suits their requirements.
Years of design and research went go into this deep-cycle lithium batteryYears of design and research went into this deep-cycle lithium battery
Weight is always an important consideration when it comes to caravanning and camping gear, but to help keep the numbers under control, the iTECH120X lithium battery was designed to be not only compact but lightweight, weighing in at only 10kg.
The heavy-duty ABS construction is designed to be durable and features vibration resistance so that it offers optimum performance throughout your outdoor escapades. Additionally, the iTECH120X lithium battery has a certified IP67 waterproof rating and is Australian tested and certified to IEC:62619 standards — meaning it is waterproof, dustproof and as safe as possible. This allows owners to confidently head offroad with its durable design, which will withstand Australia’s tough and harsh conditions. The IP67 rating also means the iTECH120X lithium battery can be externally mounted on vehicles, making it an appealing choice for outdoor enthusiasts, RV owners or those who want to beef up their tow vehicle’s power capacity for trips without the van in tow. And by adding iTechworld's heat shield it can also be suitable for under-bonnet applications.
To see more of iTechworld’s deals and bundles, visit iTechworld’ Burswood showroom in Perth, WA, call the team on 1300 483 249 or head to iTechworld’s online store.
Find out more about iTechworld's range of products, including lithium batteries, lithium power stations, petrol generators, solar power solutions, jump starter options and more here:
Power your off-grid adventures with iTechworld
Australia’s Ultimate Power and Battery Management Solutions: iTechworld
