More storage solutions with MSA 4X4 Accessories - Caravan World Australia
MSA 4X4 Accessories has a great lineup of gear that is specifically designed to make the touring lifestyle simpler and easier.
We’ve reviewed the MSA Storage Drawer Systems before (check out John Ford’s feature where he installed the set into his LandCruiser 200 Series), and they continue to be a popular choice for Aussies who want to improve their 4WD’s storage options.
The MSA Storage Drawer Systems are available in a number of varieties to ensure have a perfect and flush fit in each specific vehicle and therefore maximise storage capacity. While the Toyota LandCruiser 300 Series MSA Storage Drawer System has been available for some time, MSA has recently added the fiver-seater version to its lineup.
Toyota LandCruiser 300 Series Five Seater MSA Storage Drawer Systems
The Toyota LandCruiser 300 Series Five Seater MSA Storage Drawer Systems are made to suit the GX, Sahara ZX and GR Spots models, and there are three versions available:
  • 300 Series Double Storage Drawer System: $3354 RRP
  • 300 Series Left Storage Drawer System: $1651 RRP
  • 300 Series Right Storage Drawer System: $1651 RRP
The new MSA Storage Drawer System for the LandCruiser 300 Series Five Seater showcasing full extension
The MSA Storage Drawer Systems include a patented slide technology and stainless-steel sealed bearings on nylon rollers which allow for a 100 per cent drawer extension and easy access to the entire drawer. This means you’ll always be able to see and find everything within the drawer — no more forgetting about the things that get shoved to the back or having to unpack everything to reach them.
Another key feature is the patented ‘Stay-Open Block’ that ensures the drawer will remain in its open position even when you’re parked on a 30-degree slope.
The MSA Storage Drawer Systems also feature an internal LED light strip for easy visibility, a safe and secure lock system, dust resistant seals and removeable wing and face panels. The durable aluminium construction has been crash tested and certified as per Australian Design Rules to be ADR compliant.
The MSA Storage Drawer System has various accessories available, including a left and right side Explorer Power Panels and left and right side Pre-Cut Panels shaped to mount the Power Panels.
All MSA Storage Drawer Systems are backed by the MSA 4X4 Accessories Lifetime Guarantee.
Under Drawer Base Frame Trays
The MSA 300 Series Storage Drawer Systems have an exclusive accessory: the Under Drawer Base Frame Trays.
MSA Under Drawer Base Frame Trays in the LC300 Five Seater
These trays are an innovative storage solution and utilise unused space beneath the MSA Storage Drawer Systems and are designed to secure important auxiliary items (such as additional batteries, compressors, the air tank and other accessories) in a safe and secure location that is out of sight but still accessible from behind the rear seats.
Secure storage beneath
They are shaped to easily fit into the setup and be simple to install with no drilling required. Each tray is made with powder-coated aluminium components and is backed by MSA 4X4’s Lifetime Guarantee.
These can be purchased to suit the Storage Drawer Systems you have installed:
  • Under Drawer Tray Rear Universal (x1): $75 RRP
  • Under Drawer Tray Left: $100 RRP
  • Under Drawer Tray Right: $100 RRP
For further information about MSA 4X4 Accessories’ products, head here.
MSA 4X4 Accessories | High quality gear for towing
MSA 4X4 Accessories launches new clothing merchandise range
New MSA 4X4 Accessories gear: Storage, coffee and cutlery
