DIY: Installing an Elecbrakes EB2 brake controller - Caravan World Australia
Written by: John Hughes
John Hughes takes us through the DIY installation of the plug and play Elecbrakes EB2 brake controller which is managed via a smart phone app.
Caravans have their own brakes to help slow the rig down so the tow vehicle doesn’t have to do all of the braking. This is usually achieved by fitting an aftermarket device known as a brake controller into the tow vehicle. The brake controller sends a signal to the caravan brakes when you put your foot on the brake in the car. You can also operate the caravan brakes independently of the car by pressing an override button.
These conventional brake controllers are great but just like everything in life they have their little downsides:
  1. The brake controller is hardwired to the tow vehicle and can’t be easily moved to another car to perform towing duties
  2. As they are hardwired this is a job usually performed by an auto electrician — i.e., not DIY.
Various companies provide portable brake controllers that can be moved from car to car enabling cars without hardwired brake controllers to tow a caravan. An innovative product known as Elecbrakes EB2 has an alternative solution where the brake controller is mounted to the caravan and managed through a phone app (Apple or Android) or optional remote. The system is plug-and-play and intended for DIY installation which we run through in this story. For brevity we have not pictured every step in the phone app set up.
The instructions call for the unit to be screwed to the A-frame. This is all fine if you only want the device to work with one caravan. However, our install includes a simple hack creating a basic mounting plate that enables the controller to be moved from one van to another. (Note — the system may need to be recalibrated if it is moved to another van, which is easy to do.) In classic DIY tradition, the mounting plate is knocked together with bits and pieces I had lying around in the shed. Alternative materials could be used to create a similar result.
Preparation
You will need to order a suitable adaptor to match your car and caravan trailer connections to enable installation. A phone cradle will also make it easier for initial set up and to view system status while in use.
Next you will need to choose a location to mount the unit on the A-frame which does not interfere with the operation of other devices such as the jockey wheel or obscure information plates affixed to the A-frame. The unit must be mounted parallel to the ground but can be oriented in any position, such as along the top, inside, outside or the bottom of the A-frame. I would suggest under the A-frame would be the last choice due to vulnerability to stone damage or striking the ground. In this instance, we mounted the unit upside down to enable the connection to be pointing in the right direction.
Mount the brake controller
STEP 1: a) Screw the unit to the A-frame with the self-tapping screws providedSTEP 1a: Screw the unit to the A-frame with the self-tapping screws provided
STEP 1b: Or mount the unit to the A-frame using a simple DIY fabricated mounting plateSTEP 1b: Or mount the unit to the A-frame using a simple DIY fabricated mounting plate
STEP 2: The supplied adaptor cord has three connection points. Connect the Deutsch plug into the socket on the brake controller unitSTEP 2: The supplied adaptor cord has three connection points. Connect the Deutsch plug into the socket on the brake controller unit
STEP 3: Connect the caravan trailer plug to the trailer socket on the adaptorSTEP 3: Connect the caravan trailer plug to the trailer socket on the adaptor
STEP 4: Connect the trailer plug on the adaptor to the trailer socket mounted on the tow vehicleSTEP 4: Connect the trailer plug on the adaptor to the trailer socket mounted on the tow vehicle
Connect the brake controller to the phone app
STEP 1: Turn the car lights and keep them on while using the brake controller — this activates power to the unitSTEP 1: Turn the car lights and keep them on while using the brake controller — this activates power to the unit
STEP 2: Tap your phone on the unit to find the Elecbrakes app (you can also search online for it)STEP 2: Tap your phone on the unit to find the Elecbrakes app (you can also search online for it)
STEP 3: Download and open the Elecbrakes appSTEP 3: Download and open the Elecbrakes app
STEP 4: Allow Bluetooth connectionSTEP 4: Allow Bluetooth connection STEP 5: Find your deviceSTEP 5: Find your device
STEP 6: The app will confirm your deviceSTEP 6: The app will confirm your device
STEP 7: You will be prompted to put your foot on the brake — check if the van brake lights come onSTEP 7: You will be prompted to put your foot on the brake — check if the van brake lights come on STEP 8: You will be prompted to mount your phone in a cradleSTEP 8: You will be prompted to mount your phone in a cradle
Brake configuration and set up
STEP 1: You will be prompted to configure brake responsesSTEP 1: You will be prompted to configure brake responses
STEP 2: Follow prompt to drive at walking speed, then set braking force by scrolling the numbersSTEP 2: Follow prompt to drive at walking speed, then set braking force by scrolling the numbers STEP 3: Follow prompt to drive at 40km/h, then set a braking force by scrolling through the numbersSTEP 3: Follow prompt to drive at 40km/h, then set a braking force by scrolling through the numbers
STEP 4: Follow prompt to reverse, then set a braking force by scrolling through the numbersSTEP 4: Follow prompt to reverse, then set a braking force by scrolling through the numbers STEP 5: Follow prompt to set the override braking force by scrolling through the numbersSTEP 5: Follow prompt to set the override braking force by scrolling through the numbers
STEP 6: You will be advised brake configuration is completedSTEP 6: You will be advised brake configuration is completed
STEP 7: You will be asked if you will be using optional Elecbrakes remote (alternative to operating with phone)STEP 7: You will be asked if you will be using optional Elecbrakes remote (alternative to operating with phone)
STEP 8: You will be advised the setup is complete and ready to goSTEP 8: You will be advised the setup is complete and ready to go
Operation
STEP 1: When brakes are not activated a tick will appear on the screen. Pressing the tick will apply the override brakesSTEP 1: When brakes are not activated a tick will appear on the screen. Pressing the tick will apply the override brakes STEP 2: When you put your foot on the brake the app will show ‘BRAKING’STEP 2: When you put your foot on the brake the app will show ‘BRAKING’
STEP 3: The app has a number of ‘programs’ which enable you to have various pre-set braking calibrations for different applicationsSTEP 3: The app has a number of ‘programs’ which enable you to have various pre-set braking calibrations for different applications
STEP 4: Settings can be selected to monitor the status of the systemSTEP 4: Settings can be selected to monitor the status of the system STEP 5: Elecbrakes can also be operated through Apple CarPlay or Android AutoSTEP 5: Elecbrakes can also be operated through Apple CarPlay or Android Auto STEP 6: This is how it appears on the screenSTEP 6: This is how it appears on the screen
Thoughts on the Elecbrakes EB2 controller
Offering an alternative to a permanently installed brake controller is a winner for some users. The unit is easy to install and configure. Most importantly, the van brakes worked well, providing status feedback through the phone app without any issues during our brief testing. Technically you don’t need to have the app open for the Elecbrakes EB2 to work, but you do need it open to operate the important safety feature override switch. Alternatively, it can be controlled with an optional remote.
It’s great that you can choose to display the app directly on the phone or Apple CarPlay/Android Auto. This gives you options to display other applications in addition to the Elecbrake app. There is also the issue of the legality of touching the phone while driving. Operating the system through Apple CarPlay/Android Auto solves that problem. If you don’t like the idea of Apple CarPlay/Android Auto being used to display the app, then the optional remote is worth considering.
I think the touchscreen override switch has pros and cons. With practice you can learn to reach for and operate traditional tactile override switches by feel without taking your eyes off the road. I don’t believe this is possible with the screen-based switch on Elecbrakes.
However, the screen-based override switch is very easy to see and arguably easier for unfamiliar operators to activate. When you touch the Elecbrakes screen override switch the brakes stay on until you touch it again to turn them off. Traditional override brakes revert to off when you take your hands off the switch. I can see operators accidentally activating or leaving on the override brake function until they become familiar with the system.
I believe there is merit in developing some form of robust universal mounting system so that the Elecbrakes could be easily moved from one caravan to another. Overall, I think Elecbrakes is a great idea for people needing to use multiple tow vehicles (and with adaptation) multiple trailers/caravans.
Thanks to Andrew Phillips and the team from the RV Repair Centre, 120 Canterbury Road, Bayswater North Vic 3151, P: 03 9761 4189
DIY: Installing a Black Jack Trailer Jack
DIY: How to replace a caravan handbrake cable
DIY: Installing a Cuddy composting toilet in your van
