Your trailer plug is a part that often needs replacing. They can fail from old age or get damaged from falling out of the car connection and being dragged down the road. Replacing the trailer plug is a fairly simple and inexpensive task and the RV Repair Centre steps us through it.
Starting with the basics, the connector attached to your caravan has male pins and is referred to as the trailer plug. The connector attached to your car has matching female sockets and is referred to as the trailer socket.
In this instance, we are replacing a 12-pin plug. The trailer plug is made up of two rows of pins. One of the rows has seven smaller pins which are used for the van lighting and trailer brakes. The second row has five larger pins used to power accessories in the van.
The trailer light/brake wires follow a convention of colours and positioning in the seven-pin plug/connector row. It is important to follow a plug wiring diagram to position the wires correctly as seen here. Be careful not to get confused with the plug wiring diagram and the pin wiring diagram as they are the inverse of each other. The five-pin plug/connector (accessories) does not follow a convention as it will vary from installation to installation. Therefore, there is not a diagram for the five-pin row. After removing the covers, it is a good idea to take photos of the wiring on both rows to refer back to when reinstalling the wires.
Replacing a trailer plug:
Thanks to Andrew Phillips and the team from the RV Repair Centre, 120 Canterbury Road, Bayswater North Vic 3151, P: 03 9761 4189.
