iTechworld Solar — free, renewable power wherever the sun shines - Caravan World Australia
Harnessing free, limitless energy from the sun has never been easier. iTechworld’s solar blankets, mats, flexible panels and hard-frame panels are purpose-built to power your next adventure, wherever it takes you. Designed for Aussie conditions and engineered for real off-grid reliability, they give you the freedom to travel further, stay longer and enjoy silent, emission-free power anywhere under the sun.
iTechworld 200W Solar Mat and flexible panels
When space and weight matter, iTechworld’s 200W Solar Mat and flexible panels deliver serious charging performance in an ultra-portable package. Folding down to less than 500mm square, the 200W Solar Mat is easy to store behind seats or in canopy bags and sets up in seconds with a simple plug-and-play XT60 connection.
iTechworld’s flexible panels use advanced HPX PRO technology for unparalleled efficiency and durability in a bendable, lightweight format that conforms to curved surfaces, perfect for camper pop-tops, windscreens, boat hulls and unique mounting areas. Wherever the sun hits, you can harvest its energy.
iTechworld Solar Blanket range
iTechworld’s Solar Blanket range takes portable solar to the next level with advanced engineering and true Aussie-tough durability. At the heart of every blanket is iTechworld’s exclusive Raptor Skin coating, offering anti-reflective, scratch-resistant, UV-resistant, self-cleaning and non-stick protection. This innovative layer helps maintain optimal cell temperatures, delivering efficient charging even in harsh sun, low light or partial shade. Built with A-grade monocrystalline cells and encased in rugged 600D ballistic nylon, these blankets are hail-proof, shock-resistant and rated IP64 for all-weather performance. Folding compactly for easy transport and storage, iTechworld’s solar blankets are the perfect ready-to-go solution for travellers who want maximum efficiency, durability and freedom on every adventure.
iTechworld hard-frame panels
For adventurers building a more permanent solar system, iTechworld’s hard-frame panels offer exceptional efficiency and durability. At just 6mm thick for the 170W and 17mm for the 250W, these panels deliver big power in a low-profile design that tucks neatly under racks and caravan fairings without adding bulk. Fully sealed against dust, water and harsh UV, they’re made to survive corrugated tracks, coastal salt spray and scorching Aussie summers. Each panel features A-grade monocrystalline cells, anodised aluminium frames and pre-wired leads, making installation quick, clean and hassle-free.
Go further with iTechworld
Going solar means more than choosing the right panel — it’s about choosing freedom. Ditch the generator noise, fumes and fuel stops. With iTechworld solar, your campsite, boat or 4WD becomes a self-sustaining power hub. Pair any of the panels with an iTechworld power station or battery system and enjoy clean, reliable power for fridges, lights, tools, communications and all the gear that makes life outdoors easier. As long as there’s daylight, you’ve got energy.
Whether you’re weekending or touring full-time, iTechworld’s solar range is built to scale. Start with a simple mat or blanket, then expand your setup with hard-frame panels as your needs grow. Mix different panel types, link them for more output and adapt your system to any rig, caravan, 4WD, camper or boat. Every product is backed by real Aussie support and expertise, so you can travel with confidence knowing your energy system is built for the conditions you explore.
Why choose iTechworld Solar?
• Free, renewable power wherever the sun shines
• Ultra-portable options for tight spaces and lightweight setups
• High-output permanent panels for long-term off-grid living
• Durable, weather-sealed construction made for Australian terrain
• Plug-and-play simplicity with no complex installation
• Scalable systems that grow with your adventures
• Aussie-owned experts supporting you every step of the way
With iTechworld, you’re not just buying solar; you’re unlocking unlimited, clean energy that keeps you exploring without compromise. Wherever your journey leads, let the sun power it!
iTechworld: Upgrade your power setup for off-grid travel
New and innovative tech from iTechworld
