Fridge
Mawby Hook: The Australian Towing Upgrade Every Caravan Owner Needs
Written by: Caravan World Team
The Mawby Hook: The Australian Innovation That Makes Caravan Towing Easier, Safer and Faster
Whether you're towing a caravan around Australia, heading away with the camper trailer for the weekend or hauling a work trailer every day, there's one job every tower knows all too well - connecting the safety chains.
It's hardly the most glamorous part of towing, but it's certainly one of the most important.
For decades, drivers have relied on traditional bow shackles to connect trailer safety chains to the towbar. While they get the job done, they're often awkward to use, particularly when they're dirty, rusty or difficult to access beneath the rear of the vehicle.
That's where the Mawby Hook comes in.
Designed and engineered in Australia by DIX Engineering, the Mawby Hook is a simple yet ingenious towing accessory that replaces conventional safety chain shackles with a purpose-built quick-action coupling. It's one of those products that makes you wonder why someone didn't think of it years ago.
If you're regularly hitching and unhitching a caravan, camper trailer, boat trailer or work trailer, this small upgrade can make a surprisingly big difference.
Why Safety Chains Matter
Every caravan and trailer relies on safety chains as a critical backup should the unlikely event occur that the trailer becomes disconnected from the towball.
Australian Design Rules require safety chains to remain securely attached to the tow vehicle while towing, making them one of the most important components of any towing setup.
Unfortunately, connecting those chains isn't always straightforward.
Traditional bow shackles require the threaded pin to be removed, lined up through the chain and towbar mounting point, then tightened again - often while lying on the ground or reaching into awkward positions. Add a bit of mud, dust or surface rust and the process becomes even more frustrating.
For travellers who tow every weekend or spend months touring Australia, it's a job that quickly becomes tiresome.
chain links
A Smarter Way to Tow
The Mawby Hook was developed specifically to eliminate these everyday frustrations.
Rather than using removable threaded shackles, the Mawby Hook provides a quick-action hook system that allows you to connect or disconnect your safety chains in just seconds.
The design is incredibly simple, yet highly effective.
Instead of fumbling with pins and threads every time you tow, the hook provides fast, secure attachment that significantly reduces the time spent hitching up.
It doesn't change how your trailer tows.
It simply makes preparing for the journey quicker and far less frustrating.
Whether you're heading out for a quick overnight trip or setting off on the Big Lap, it's one less hassle before you hit the road.
Designed and Engineered in Australia
One of the standout features of the Mawby Hook is that it's proudly designed and engineered in Australia.
Designed by DIX Engineering in Renmark, South Australia, every Mawby Hook has been developed with Australian roads, Australian trailers and Australian touring conditions in mind.
Unlike many towing accessories, this is a product designed by people who understand exactly what Australian caravan owners expect from their equipment.
From corrugated outback roads to thousands of kilometres of highway touring, durability and reliability are at the forefront of the design.
Engineered for Strength
Convenience means nothing if a towing product can't deliver on strength.
Fortunately, the Mawby Hook has been engineered with both in mind.
Manufactured from high-strength drop-forged steel, the Mawby Hook has been independently tested to comply with Australian Standard AS4177.4 and is rated for trailers with an Aggregate Trailer Mass (ATM) of up to 3.5 tonnes.
That makes it suitable for the overwhelming majority of:
  • Caravans
  • Hybrid caravans
  • Camper trailers
  • Boat trailers
  • Horse floats
  • Box trailers
  • Tradesperson trailers
It's worth noting that the Mawby Hook is designed specifically as a towing safety chain connection and is not intended for lifting applications.
safety chain
Installation Is Surprisingly Simple
One of the reasons the Mawby Hook has become so popular is that installation is refreshingly straightforward.
Rather than replacing your entire towbar setup, the Mawby Hook is designed to fit most standard Australian towbars, making it an easy upgrade for existing towing systems.
Once installed, it stays on your vehicle, ready whenever it's time to tow.
That means no more searching through the toolbox for shackles.
No more seized threads.
No more scraped knuckles trying to tighten pins underneath the vehicle.
Instead, connecting your caravan becomes a much faster and more enjoyable part of preparing for your next adventure.
Built for People Who Tow Regularly
Some accessories only get used once or twice a year.
The Mawby Hook is different.
If you're someone who:
  • Takes regular caravan holidays
  • Frequently moves a camper trailer
  • Tows a boat every weekend
  • Uses trailers for work
  • Owns multiple trailers
...you'll use the Mawby Hook every single time you hitch up.
It's one of those upgrades that continues paying dividends because it saves time on every journey.
Many owners say it's not until they switch back to traditional shackles that they realise just how convenient the Mawby Hook really is.
Added Security
Another clever feature of the Mawby Hook is its pilfer-resistant design.
Unlike standard bow shackles that can often be removed quickly with simple hand tools, the Mawby Hook incorporates a design that makes unauthorised removal significantly more difficult.
While no accessory can completely eliminate theft, it's an added layer of security that many caravan owners appreciate, particularly when travelling or leaving their rig parked for extended periods.
Small Upgrade. Big Convenience.
It's easy to spend thousands of dollars upgrading suspension, installing lithium batteries or fitting solar systems.
Yet sometimes the most satisfying improvements are the smallest ones.
The Mawby Hook doesn't promise more horsepower.
It won't increase your towing capacity.
It won't make your caravan lighter.
What it will do is improve one of the most repetitive tasks involved with towing.
Considering you'll connect and disconnect your safety chains hundreds - perhaps thousands - of times throughout the life of your caravan, that's an improvement you'll appreciate every trip.
Caravan World's Introductory Offer
To celebrate the arrival of the Mawby Hook at Caravan World, we're offering an introductory price of just $115, reduced from the regular retail price of $139.
That's a saving of 17%, making now the perfect time to upgrade your towing setup before your next adventure.
For little more than the cost of filling your fuel tank, you'll replace an everyday annoyance with a solution that's quicker, easier and purpose-built for Australian touring.
Whether you're preparing for a lap around Australia, planning a weekend away or simply want to make hitching up less of a chore, the Mawby Hook is one of those rare accessories that delivers genuine convenience every single time you tow.
But like all introductory offers, this pricing won't last forever. If you've been considering upgrading your towing equipment, now is the ideal opportunity to pick one up and experience why so many Australian caravan owners are making the switch.
Final Thoughts
The best caravan accessories aren't always the biggest or the most expensive - they're the ones that solve real-world problems.
The Mawby Hook is exactly that.
Designed and engineered in Australia, it combines strength, compliance and clever engineering into a simple product that makes towing easier every time you head off on the road.
It's quick to use, built to last, easy to install and backed by Australian engineering expertise.
If you're tired of wrestling with traditional bow shackles every time you hitch up, the Mawby Hook is an upgrade you'll appreciate from the very first trip.
And with Caravan World's limited-time introductory price of just $115 (normally $139), there's never been a better time to make the switch.
Shop Now!
Chains and Hook
