Top Tow Tugs of 2022
An increase in towing capacity means you can take your pick of vans
The second-generation MU-X is again based on the proven platform and mechanics of the D-MAX, but with key changes that make the family wagon arguably even better suited as a long-range tourer and tow-rig. With its stronger body-on-frame chassis, re-engineered coil-sprung multi-link rear suspension, and increased front and rear axle load ratings, the new MU-X now boasts enhanced braked towing capacity of 3500kg with a 350kg ball load — that’s an improvement of 500kg and 50kg respectively on the previous model, giving the MU-X an advantage over rivals like the Ford Everest, Mitsubishi Pajero Sport, and Toyota Fortuner. Under the new-look bodywork is a stronger chassis that makes more use of high-tensile steel, with larger chassis rails, an additional crossmember, and new rear subframe cradle.
Inside, the flagship LS-T features quilted leather-accented upholstery, remote engine start, auto-dim rear-view mirror, tyre pressure monitoring and a 9in high-definition infotainment system (with rear camera). Other handy features include front and rear park sensors, reversing camera, and a power tailgate that provides access to the generous 1119L boot. Three rows of seating provide family hauling versatility, with roof-mounted air vents across the rear rows and fan controls for row two.
Safety kit extends to eight airbags, including a driver’s knee airbag and a centre front airbag, plus a comprehensive suite of intelligent driver assistance (IDAS) technologies with autonomous emergency braking, lane keeping, and trailer sway control. Under the bonnet is a heavily re-engineered version of Isuzu’s proven 3L turbodiesel, putting 140kW/450Nm through a new six-speed auto to deliver confident and reasonably fuel-efficient towing ability.
Price: $65,900 (MRLP)
Engine: 3L turbodiesel 4-cylinder (140kW/450Nm)
Transmission: Six-speed automatic
Towing unbraked/braked: 750kg/3500kg
Kerb Weight: 2175kg
Gross Vehicle Mass: 2800kg
Payload: 225kg (at maximum 3500kg tow rating)
Gross Combined Mass: 5900kg
Fuel Capacity: 80L
Fuel Consumption: 8.3L/100km (ADR Combined Cycle)
Safety Rating: 5 Star (2020)
Warranty: 6-years/150,000km
TOYOTA LANDCRUISER PRADO GXL
As with the Patrol, the arrival of the LandCruiser 300 Series has made the Prado look a little long in the tooth.
Keep your eyes peeled, as rumour has it another update may be on the cards
This generation of the so-called ‘son of LandCruiser’ has been with us since 2009 and there’s speculation an all-new model will drop in 2023. Despite this, Toyota has kept the Prado competitive with two major facelifts and several minor updates during its lifecycle, the most recent of which came in July 2021. The updated Prado now features blind spot monitoring and rear cross traffic alert as standard on the entry level GX and GXL variants, joining the raft of previously available features such as high-speed active cruise control, lane departure alert with steering assistance, and pre-collision safety system with day/night pedestrian and daytime cyclist detection. The GX grades also feature more premium exterior appointments, including chrome-accented grille and puddle lamps, while the upmarket VX and Kakadu variants have been upgraded with larger and newly designed 19in alloy wheels.
The Prado remains a step below its heavyweight ‘father’ in terms of towing capacity, even despite a 2020 upgrade which boosted its braked towing credentials from 2500 to 3000kg. That update also boosted the performance of the durable 2.8L four-cylinder turbodiesel, with outputs bumped up to a healthier 150kW/500Nm. It’s the same unit used in HiLux and Fortuner so is well proven and mates to a six-speed automatic. With its strong ladder frame chassis, all-coil independent front and live axle rear suspension, the Prado is a solidly dependable tow rig that handles mid-weight towing duties comfortably. A reversing camera with guidelines helps when hitching up, while the driving position, comfort levels, and finishes are all to Toyota’s usual high standard.
Price: $67,530
Engine: 2.8L four-cylinder turbodiesel (150kW/500Nm)
Towing unbraked/braked: 750kg/3000kg
Kerb Weight: 2855kg
Gross Vehicle Mass: 2990kg
Payload: 705kg
Gross Combined Mass: 5990kg
Fuel Capacity: 150L
Fuel Consumption: 7.9L/100km (ADR Combined Cycle)
Safety Rating: Five Star (2011)
Warranty: 5-years/unlimited km
SUBARU OUTBACK AWD TOURING
Subaru introduced the sixth generation of its popular Outback wagon in March 2021, the new BT Series model replacing the four-year-old BS in simplified three-variant range. The new line up comprises Outback AWD, Outback AWD Sport and our pick, the Outback AWD Touring.
Subaru claims the Outback’s heavily revised 2.5L four-cylinder ‘Boxer’ engine is 90 per cent new, adopting direct fuel-injection and other changes that boost power and torque to 138kW/245Nm. The extra grunt has facilitated a handy 500kg boost to the new Outback’s braked towing capacity, which is now 2000kg.
You have 552L of boot space to play with
Other technical changes include refinements to the continuously variable transmission, which features a wider spread of ratios for improved take-off acceleration and better fuel efficiency.
The well-appointed, roomy, and practical cabin offers space for five adults and impressive versatility via a flat load lip, underfloor full-sized spare, multiple tie-downs, and 60/40 split-fold rear seats. Accessing the generous 522L boot is also now easier thanks to a wider-opening electric tailgate. The attractive new dash design features a vertical orientation 11.6in infotainment system, providing centralised controls of vehicle and multimedia functions.
While you wouldn’t tackle the Simpson in it, the Outback also has a handy degree of rough terrain capability courtesy of 213mm of ground clearance, constant all-wheel drive, and Subaru’s X-Mode multi-terrain traction system. The ace up the Outback’s sleeve compared with most other vehicles here is its impressively comfortable and car-like driving manners, characterised by long-travel suspension that delivers excellent ride characteristics, and keen cornering grip in bends.
Safety wise, the Outback features a new inner frame structure for enhanced occupant protection, a new passenger seat cushion airbag, plus the latest generation of Subaru’s EyeSight Driver Assist system, with its wide range of advanced driver assistance features.
Price (MRLP): $63,180
Kerb Weight: 2110kg
Gross Vehicle Mass: 3050kg
Payload: 1105kg
Gross Combined Mass: 5850kg
Fuel Capacity: 80L
Safety Rating: 5-Star ANCAP (2019)
CHEVROLET SILVERADO 2500 LTZ PREMIUM HD
If you’re looking at the specs panel and thinking that 1243Nm torque figure must be a typo, you’d be wrong. Put it down to the growling 6.6L Duramax turbodiesel V8 in the snout of the hulking Chevrolet Silverado LTZ Premium HD, the biggest stick in the armoury of GMSV, the company that rose from the ashes of Holden in November 2020.
With the latest and greatest in tech, you'll be travelling safely
Like its stablemates the Silverado LT Trail Boss and the LTZ Premium, the HD (for heavy duty) is imported from the US and re-engineered to right hand drive by Walkinshaw Automotive Group. Unlike its petrol V8-powered namesakes, however, the Silverado HD drinks the oily stuff, which accounts for its suburb-shifting torque and prodigious tow rating.
The luxurious interior fit out includes driver and front passenger heated and ventilated leather seats, heated leather steering wheel, 15in colour head-up display and an 8in driver information centre. Standard safety kit runs to front and rear park assist, lane change alert with side blind zone alert and rear cross traffic alert, low speed forward automatic braking, front pedestrian braking, automatic headlamp control, following distance indicator, safety alert seat and electronic stability control with traction control.
The over-sized cargo bed measures 2104mm long, 1814mm wide and can accommodate 1968L of volume, with 12 tie-down points.
In a nice touch we don’t often see on Aussie utes, the HD also features a power up and down tailgate that can be opened or closed using the key fob, a button on the tailgate, or a dash switch. Even that’s trumped, though, by the HD’s ‘invisible trailer’ feature which uses a pair of cameras to create and process images, which makes the item being towed disappear from the rear view. The advanced towing package also includes rear vision camera hitch guidance, hitch view, integrated trailer brake controller, and power extendable external mirrors.
Price: $144,990 (MRLP)
Engine: 6.6L Duramax turbodiesel V8 (332kW/1234Nm)
Transmission: 10-speed automatic
Towing unbraked/braked: 750kg/4500kg
Kerb Weight: 3752kg
Gross Vehicle Mass: 4495kg
Payload: 743kg
Gross Combined Mass: 12,474kg
Fuel Capacity: 136L
Fuel Consumption: Not available
Safety Rating: Not yet rated by ANCAP
Warranty: 3-years/ 100,00km
2022 FORD RANGER 4X4
It’ll be mid-2022 before we finally get to see Ford’s all-new Ranger in the metal, but the Blue Oval has revealed much of what we need to know already via pre-launch teasers.
Like its predecessors, a range of eye-catching colours are likely to be on offer
Headlining the comprehensive changes is the introduction of a new 3L twin turbodiesel V6 with 10-speed automatic and a full-time 4x4 system on selected models. The current 2L four-cylinder turbodiesel will continue in either single or bi-turbo configurations. Ford Australia held back on releasing power, torque, or economy figures but the V6 is the same ‘Powerstroke’ unit the company has previously used Stateside in the F-150, where it puts out a healthy 190kW/600Nm.
Other notable changes include an all-new exterior design that lends the Ranger a far more muscular presence, and a new-look interior that’s more comfortable and high tech. The new dash showcases a new digital widescreen instrument cluster and tablet-style infotainment screen, incorporating Ford’s latest and greatest SYNC 4 connectivity and entertainment system. A schmick new offroad monitor and 360-degree camera will be handy when hitching up, while other new features include clever new storage systems inside the cabin, an integrated sidestep behind the rear wheel on either side of the tub, and all-round ‘zone’ lighting for when working or setting up camp at night.
A longer wheelbase and widened track are part of a heavily revised suspension set-up, with the tray also widened by 50mm to now accommodate a full-size palette. The widening of the suspension allows greater axle articulation for better offroad traction, according to Ford, while the front wheels have been moved 50mm closer to the front to improve the approach angle.
With full pricing and technical details yet to be released, including the maximum tow rating (which we expect will remain at 3500kg), we’ve chosen to hold off on publishing speculative specifications.
Coming soon
BMW X5 XDRIVE 30D M SPORT
The fourth-generation BMW X5 delivers handsomely on the German brand’s promise of eager performance and engaging dynamics, but in this case, the German SUV can also tow a decent load. The 2018 introduction of a factory-designed and installed towing hitch receiver, bespoke control unit and specific vehicle wiring harness is one of the automotive world’s better kept secrets but enables the X5 to handle loads of up to 3500kg braked, with a 280kg maximum downball load.
As part of the package, the standard surround view camera system offers an additional zoom function for the rear camera, while a trailer stabilisation system is also included. Under the X5’s chiselled bonnet is a 3L twin turbodiesel, delivering a smooth and lag-free 195kW of power and chunky 620Nm of torque. It’s all channelled through a crisp-shifting and intuitive eight-speed auto, and BMW’s proprietary xDrive all-wheel drive system.
Those who like to travel in luxury will be happy with this one
The roomy and beautifully trimmed interior features an attractively designed high-tech dash with all the latest connectivity bells and whistles, including factory navigation and compatibility for Apple and Android smartphones.
The X5 M Sport also comes with optional adaptive air suspension, featuring a self-levelling function and adjustment for five different ride height levels, with a total sweep of 80mm. Thus equipped, the rear of the vehicle can be separately lowered via a tailgate button, to aid rear compartment loading and hitching. And contrary to the popular belief that BMWs are exclusively tarmac tearaways, the X5 also offers an optional BMW xOffroad Package, featuring aluminium underbody protection, an electronically controlled rear differential lock, and selectable drive modes for sand, rocks, gravel, and snow.
Imagine the look on the faces of those LandCruiser and Patrol owners when you come bumping into their off-the-beaten track campsite in your Bavarian bullet. Guten tag!
Price: $121,900 (MRLP)
Engine: 3L turbocharged inline six-cylinder diesel (195kW/620Nm)
Transmission: EIght-speed automatic
Kerb Weight: 2110kg
Gross Vehicle Mass: 2860kg
Payload: 750kg
Gross Combined Mass: 6360kg
Fuel Capacity: 80L
Fuel Consumption: 7.2L/100km (combined)
Safety Rating: 5 Star (2018)
Warranty: 3-years/unlimited km
RAM 1500 DT LIMITED CREW CAB
It seems there’s a locally remanufactured RAM for every stump-pulling job these days, with the new-for-2021 RAM 1500 DT Series joined during the year by the heavy-duty RAM 2500, and later still the biggest and baddest of them all: the RAM 3500 Laramie with its mammoth 1724kg payload.
More American utes are popping up on Aussie roads, and it’s clear why
For most caravanners trying to find the sweet spot between size, towing capability, and driving manners, we still rate the RAM 1500 DT as the pick despite it being available only with the 5.7L Hemi petrol V8. Despite this, it seems that even those hard-headed Yanks are getting the message about fuel consumption and greenhouse gases, with the new RAM boasting such fuel-saving tricks as active aerodynamic grille shutters and air dams, and cylinder deactivation. The 1500 DT also features a new eTorque mild hybrid system, designed to further improve efficiency and driveability. The system combines a belt-drive motor generator unit with a 48V battery pack to enable its start/ stop function, short-term torque assist, and brake energy regeneration. The result is a still mighty 291kW of power and 556Nm of grunt, but surprisingly reasonable combined cycle fuel consumption of 12.2L/100km.
Out on the road, the RAM 1500 feels every bit the big, barrel-chested beast that its imposing dimensions suggest, its substantial heft resisting side-winds and being bullied about by the trailer to ensure impressive towing stability. The Laramie comes loaded with kit — we’d spoil ourselves here and opt for the Limited, with its air suspension, electric auto-deploy side steps and suite of active safety features including adaptive cruise control, forward collision warning, pedestrian detection, ready alert braking, and trailer-sway damping control.
Other standard inclusions of the Limited include 22-inch alloys, power release tailgate, 900-watt Harman Kardon Sound System, and 60/40-split reclining rear seats with outer seat heating.
Price: $139,950 (MRLP)
Engine: 5.7L V8 petrol (291kW/556Nm)
Transmission: 8-speed automatic
Kerb Weight: 2749kg
Gross Vehicle Mass: 3450kg
Payload: 701kg
Gross Combined Mass: 7713kg
Fuel Capacity: 98L
Fuel Consumption: 12.2L/100km (combined)
Warranty: 3-years/100,000km
