In this article the RV Repair Centre shows us how to clean the freshwater and greywater tanks in our van.
One of the most fundamental functions of caravan living is access to clean drinking water and dealing with the ‘dirty’ water you create as a result of washing dishes, showering and so on. Core components of these plumbing functions are the freshwater tanks, greywater tanks and the water filter.Freshwater tanks must always be held to the highest hygiene standards to keep the water safe for drinking. Part of this process is cleaning the tank periodically with a suitable cleaning solution, flushing the cleaning solution and then adding new fresh water. Greywater tanks require a similar cleaning process with some slight variations. Inline filters used in the freshwater system need to be replaced regularly to maintain high water quality.In this article, The RV Repair Centre steps us through these processes.
Fresh water:
Empty a freshwater tank
STEP 1 Turn off the water pump
STEP 2 Turn on the taps to drain water from the lines
STEP 3 Locate the water tank drain valve and open it (partially opening it can prevent a rush of water)
STEP 4 Allow all the water to drain from the tank and close the valve
Fresh water:
Adding a cleaning solution
STEP 1 Select a suitable drinking water tank cleaning solution |
STEP 2 Add the tank cleaning solution to a suitable container following the directions
STEP 3 Mix the tank cleaning solution with drinking water following the directions |
STEP 4 Ensure that the water tank valve is closed
STEP 5 Use a funnel or similar for easy pouring
STEP 6 Pour the cleaning solution into the tank |
STEP 7 Using a trusted drinking water source, a drinking water hose and filter is best practice |
STEP 8 This water filter required a hose connector to be screwed into either end |
STEP 9 Connect the water filter to a drinking water hose |
STEP 10 Connect the drinking water hose to the tank inlet |
STEP 11 Fill the tanks |
STEP 12 Turn on the pump |
STEP 13 Run all the taps briefly to purge ‘old water’ and fill the lines with cleaning solution |
STEP 14 Top up to full capacity so the cleaning solution makes contact with all of the tank interior surfaces |
STEP 15 Allow the cleaning solution/water to sit in the tank as per instructions (about 24hrs) |
Fresh water:
Fill with fresh water
- Repeat the process of draining the tank — refer to ‘Empty a Freshwater Tank’
- Repeat the process of filling the tank with fresh drinking water — refer to ‘Add a cleaning solution’, steps 7–14
- Repeat filling and draining the tank with freshwater until you are satisfied the chemical has been flushed — The RV Repair Centre typically repeats the process 2–3 times
Grey water:
Clean the greywater tank
STEP 1 Empty the grey water tank at a designated dump point prior to commencing the cleaning process |
STEP 2 Select a suitable tank-cleaning solution |
STEP 3 Add the tank cleaning solution to a suitable container following the directions |
STEP 4 Mix the tank cleaning solution with drinking water following the directions |
STEP 5 Add the solution to the greywater tank by pouring it down the sink or shower drain |
STEP 6 Fill the greywater tank with fresh water by running the taps |
STEP 7 Top up to full capacity so the cleaning solution makes contact with all of the tank interior surfaces |
STEP 8 Allow the cleaning solution/water to sit in the tank as per instructions (about 24hrs) |
STEP 9 Empty the greywater tank at a suitable location
STEP 10 Repeat the process if the drained water still looks dirty |
Change the van Inline drinking water filter
STEP 1 Turn off the water pump |
STEP 2 Open the tap in the same line as the filter and run until no water comes out |
STEP 3 Locate the filter and place a towel under it to catch any water that may leak |
STEP 4 Rotate the filter to disengage it |
STEP 5 Remove the filter |
STEP 6 Insert a replacement filter |
STEP 7 Rotate the filter to engage it |
STEP 8 Turn the pump on |
STEP 9 Turn the tap on to allow water to run through the system |
STEP 10 Turn the tap off and check for leaks at the filter connection point |
Hacks
- Consider doing the freshwater tank clean and the greywater tank clean one straight after the other. This way you can transfer the cleaning solution/water from the freshwater tanks to the greywater tank by running the taps into the sink and/or shower. This will save water and cleaning solution.
- Some caravanners use DIY greywater tank cleaning solutions such as heavily diluted vinegar or dishwashing detergent. Check the internet for potential ‘brews’.
- Some caravanners prefer to part-fill their greywater tank with water and cleaning solution and then hit the road. Water sloshing around in the tanks creates a mechanical cleaning action to remove dirty material attached to the inside of the tank.
Improper maintenance can lead to injury, death or property damage. Maintenance work of this nature should only be undertaken by people with suitable competence. The information provided is general in nature, not comprehensive and should only be taken as a guide. Individual discretion must be exercised and persons undertaking described tasks do so completely at their own risk. Publishers and creators of this content accept no responsibility for loss or damage. Thanks to Andrew Phillips and the team from the RV Repair Centre, 120 Canterbury Road, Bayswater North Vic 3153, P: 03 9761 4189.
DIY: How to repair a Cruisemaster DO35 hitch
Drink only the best with the B.E.S.T. RV Inline Water Filter
