Tow test: MY25 Ford Everest Tremor - Caravan World Australia
Written by: Tim van Duyl and Caravan World team; Photography and videography: Tim van Duyl, Joshua Hanger and supplied
Ford’s Everest Tremor takes the already capable SUV and adds V6 grunt, tougher kit and the confidence to chase better campsites off the beaten track.
The Ford Everest Tremor is the pinnacle of the Everest range — though not in the same way as the flagship Platinum. Where the Platinum is all about luxury and comfort, the Tremor is about getting further off the beaten track while keeping the Everest’s core strengths. It’s still a seven-seater SUV, still family-friendly and tow-ready, but it’s taller, tougher and ready for bush tracks. Under the bonnet it runs our favourite Everest engine for towing, the 3L V6 diesel, and it backs that up with big all-terrain tyres, steel bash plates, extra floodlights, easy to wash floor mats and a new Rock Crawl Drive Mode.
But this is Caravan World, so naturally we want to know how it tows. But first, let’s check out the specs.
What can the Everest Tremor tow?
Like almost every vehicle out there, the Tremor can tow its maximum braked tow capacity of 3500kg — but only in very limited circumstances. With a gross combined mass (GCM) of 6350kg and a kerb weight of 2550kg, towing at the full 3500kg limit would leave you with around 300kg payload to cover passengers, gear and accessories. This means you need to pack very, very lightly if you’re planning on towing a big van.
(For a refresher on caravan weight terminology, check out our guide here.)
The Ford Everest Tremor can tow up to 3500kgThe Ford Everest Tremor can tow up to 3500kg
The GCM limit only comes into play with trailers weighing more than 3000kg. However, there is another limit to watch — the somewhat low 690kg payload. You can get gross vehicle mass (GVM) upgrade kits from the likes of Tough Dog 4WD Suspension which, personally, I would do. But after towball weight is taken into account, you will need to keep an eye on what goes into the boot and how many passengers you carry.
Some weight could be saved by removing the spare steel wheel or taking out the third-row seats. But in reality, no one is going to do that — it’s more likely owners will be adding weight, not taking it away so stay diligent.
Luckily for us, we weren’t towing a big van during our five-day test run. Instead, we paired the Tremor with a compact pod because we wanted to go that little bit further off the beaten track.
The trailer in question was the J-POD X, Jayco’s most offroad-focused pod style camper. It’s small, it’s light, it’s nimble and it’s perfect for going bush. I hauled it for 2000km from Melbourne to Cann River in eastern Victoria, through Kosciuszko National Park, up to Tumut and back across the border down through Nagambie and the Strathbogie Ranges before heading back to work headquarters in Melbourne.
We’ve done a full walkthrough video on the camper which you can watch here. In short, as we towed it, the J-POD X was about 1200kg. It sits at 1.97m (6ft 5in) wide and about 2.3m (7ft 5in) tall, with the optioned-on Escape by Jayco rooftop tent we have.
The MY25 Ford Everest Tremor towing the Jayco J-POD XThe MY25 Ford Everest Tremor towing the Jayco J-POD X
Knowing the Everest platform well, I know the Tremor could tow a lot more. But we don’t like camping in holiday parks — we’re more interested in bush camps and getting off the beaten path, and that’s exactly what the Tremor was built for.
The V6 advantage
Under the bonnet is the familiar 3L ‘Lion’ V6 Turbo Diesel. This engine debuted with the Everest and the Ranger back when this platform first came to market in 2022. Now, I love this thing. At 184kW and 600Nm, it is by far the best engine in the class. But it’s also strong, smooth and impressively quiet when towing. Don’t get me wrong, I like the 2L bi-turbo four-cylinder in other Everest variants and the Ranger Tremor — it’s a fantastic and efficient engine — but for towing, the V6’s extra grunt, along with how quiet and smooth it is, makes it our pick.
Backing up the V6 engine is Ford’s 10-speed automatic transmission. I was a bit critical of the 10-speed when it first launched at my very first tow test. Back then, I saw quite high transmission temperatures. But in the last couple of years, I’ve seen no problems with it. What I really like about it is its smooth changes, and it always feels like it’s in the right gear when you’re on the freeway towing a van. Behind the automatic gearbox there’s a transfer case that makes this a proper full-time 4x4.
The MY25 Ford Everest Tremor comes with the familiar 3L ‘Lion’ V6 Turbo Diesel engineThe MY25 Ford Everest Tremor comes with the familiar 3L ‘Lion’ V6 Turbo Diesel engine
A new drive mode
A new addition for the Everest Tremor is Rock Crawl Mode, a seventh drive program unique to this variant. This mode is designed to optimise traction, gearing and control when driving on loose and rocky surfaces and adds a tailored display to the infotainment screen when engaged.
We used Tow/Haul Mode pretty much exclusively during our tow test, but once I looked for the diff lock button when leaving a wet camp and I couldn’t find it. It turns out the Tremor does have a rear diff lock which engages when you enter the right mode, like when we used the Sand Mode while driving down to the dunes at a beach near Cann River, Vic. Alternatively, you can find the diff lock button in the centre console, which I do not think is as sensible as a switch or button like most competitors use.
Rock Crawl drive mode activatedRock Crawl drive mode activated
We were only travelling with the one vehicle, so I didn’t want to go too far offroad in case I found some trouble. But what I can tell you from the people I’ve spoken to is that the Tremor is exceptionally capable offroad when put in the right modes and makes four-wheel driving super simple. There are lots of parts that make the Tremor a good offroader and it definitely has the grunt to tow big loads.
Drive Mode controlsDrive Mode controlsThe rear diff lock engages when you enter the right mode, such as Sand ModeThe rear diff lock engages when you enter the right drive mode, such as Sand Mode
Offroad gear
Where Tremor really breaks away from other Everests is the offroad hardware.
Getting the best out of going offroad starts with the bits that are touching the ground: the tyres. The Tremor runs on General Grabber’s aggressive AT3 all-terrains in a chunky 265/70R17, wrapped around 17x8in alloys. I really appreciate the tall sidewalls on these tyres — there’s a lot of height which means you can bag out or soften the tyre by deflating it to give you more traction when offroad. The Tremor does come with a tyre pressure monitoring system (TPMS), which is a handy addition for anyone hitting the sand or towing frequently, but it doesn’t include a tyre temperature system, which I would like to see.
The MY25 Ford Everest Tremor comes with General Grabber’s aggressive AT3 all-terrain tyresThe MY25 Ford Everest Tremor comes with General Grabber’s aggressive AT3 all-terrain tyres
The tyres are matched with a slight lift from a new suspension setup featuring position-sensitive Bilstein shock absorbers/dampers with remote reservoirs and new springs, which gives the Tremor a height of 1.9m (6ft 2in) — an approximately 26mm lift over the standard Everest.
Our test vehicle featured a few optional packs, including the Rough Terrain Pack ($3550), which adds underbody armour, an auxiliary switch in the cabin (replaces the sunglasses holder) and a stylish rough terrain bar that features a pair of front recovery points. The Tremor also gets its own heavy-duty side steps, which not only look good but are much tougher than what you’ll find on the typical Everest.
This review model had the optional Rough Terrain Pack which added underbody armourThis review model had the optional Rough Terrain Pack which added underbody armour
The extra offroad gear will make this rugged 4WD SUV even more capableThe extra offroad gear will make this rugged 4WD SUV even more capable
Interior and tech
But the Tremor is more than just a powerful offroad machine — it’s also got a really nice interior to match. There’s a balance of durability and comfort inside, with a primarily black colour scheme with embossed Tremor lettering, leather accents and dark stitching. The heated powered driver’s seat is a nice touch, as are the all-weather and easy to clean floor mats that are practical additions offroad.
As standard, you get an eight-way powered driver’s seat. With the optional Tremor Premium Seat Pack ($1200) you can get another two ways of adjustment for the driver. The pack also gives eight ways of power adjustment for front passenger plus heating and ventilation for both front seats.
The 12in portrait SYNC 4 infotainment screenThe 12in portrait SYNC 4 infotainment screen
The driver gets an 8in digital instrument cluster (a small step down from the Platinum’s 12in offering), paired with a 12in portrait SYNC 4 infotainment screen. There are all the expected features of a premium modern vehicle, with wireless Apple CarPlay and Android Auto, built-in sat nav, DAB+ radio and FordPass Connect. The physical knob for volume is a nice touch, especially since good old-fashioned physical buttons are making a comeback when it comes to car safety. There’s also wireless charging, a 400W inverter (located in the boot), dual-zone climate control and an eight-speaker stereo.
The rear seats benefit from an elevated theatre-style setup, which kiddos or mates will appreciate. Leg and headroom are also good across the second row, with the third saved for shorter trips or anyone you’re not too fond of. Boot space runs from 259L with all seats up, 898L with the third row folded and a massive 1823L with both back rows down.
The rear seats are elevated with good leg and headroom across the second rowThe rear seats are elevated with good leg and headroom across the second row
Safety tech is as comprehensive as you’d expect from a modern vehicle: adaptive cruise control with stop and go, lane centring, traffic sign recognition, blind spot monitoring with cross-traffic alert, pre-collision assist with AEB and intersection assist.
Exterior design
Outside, the Tremor features a distinctive honeycomb grille design, auxiliary LED floodlights, steel bash plates, heavy-duty side steps and unique badging.
You might not need the Rough Terrain Pack, which adds on the cool front bumper, lots of extra protection underneath and the auxiliary panel above the console. But we’d recommend ticking the Touring Pack/Premium Towing Pack box ($2900) as it gets you the 360-degree camera, integrated trailer brake controller, pro trailer backup assist and towbar setup.
The Command Grey paint on our test car is exclusive to the Tremor, and a premium paint add-on ($750). Meteor Grey and Shadow Black are also available as premium options, or you can opt for Arctic White at no cost.
The Tremor has a distinctive lookThe Tremor has a distinctive look and the optional packs will make it even more capable
Price and packs
The Everest Tremor starts from $84,900 plus on-road costs. What you see here with multiple packs and premium paint will cost a little more than $97,000 drive away (Melbourne), which is a big chunk of change for anyone to swallow. But an Everest V6 commands a high price. I looked at the Everest Sport V6 with 18in wheels, the Touring Pack, premium paint and a couple of small options and it came out at around $88,000. So, for $9000 more, is the Tremor a good deal? For the bash plates alone and the front bar, which are part of the Rough Terrain Pack, and that lift and wheels and tyres, I reckon around nine grand extra for the Tremor is worth considering.
Our review vehicle had the optional Command Grey premium paintOur review vehicle had the optional Command Grey premium paint
The tow test
So, how did the Everest Tremor tow? We travelled a bit more than 2000km from Melbourne to Tumut and back down again with the J-POD in tow. During the trip our fuel consumption came in at 14.4L per 100km. And I know what you’re thinking, that’s not great for a 1200kg camper, but remember that this is a box with a rooftop tent on top. It’s hardly aerodynamic and add in the Tremor’s suspension lift and aggressive all-terrain tyres and the figure makes more sense. In a standard Everest V6 the same trip would likely have come closer to 12L/100km.
That 14.4L consumption, which I think is reasonable, will get you about 500km from the 80L tank.
The factory brake controller did a great job of the J-POD’s electric drum brakes. It always felt great under braking and very safe and progressive. Critically for me, what I enjoyed most about the Tremor and its towing performance was the confidence the grip gave me to go that little further. At a few bush camps I had the option of sticking to the safer ground or heading down long grassy or muddy tracks to reach the better spots. The confidence and offroad control the Tremor gave me meant I could go where I really wanted, so I did.
The Ford Everest Tremor towed well and gave the confidence to get to the better, if harder to reach, campsitesThe Ford Everest Tremor towed well and gave the confidence to get to the better, if harder to reach, campsites
Final thoughts
The verdict? The Everest Tremor isn’t the plushest model in the range, and it isn’t the cheapest. Instead, it’s pitched squarely at buyers who want more confidence offroad without losing out on comfort and safety for everyday travel.
With the V6 diesel engine, upgraded suspension, aggressive all-terrain tyres, bash plates and better lighting at nighttime, this is a vehicle that you’re going to have more fun with when you go camping. Towing heavy will push its limits, but for a mid-size van, camper, hybrid or careful packing, it’s a great match.
The verdict? If you like to leave the bitumen behind and want an offroad-ready SUV that can keep up with your adventures, the Tremor is a great option in the Everest lineup.
  • Strong and smooth V6 diesel engine
  • Excellent offroad gear
  • Looks
  • No tyre temperature system
  • GCM limited at high tow-weights
  • Moderate payload
MY25 FORD EVEREST TREMOR RATINGS
VALUE FOR MONEY 7/10
The next best would be an Everest Sport V6 saving $9000; both are expensive
TOWING PERFORMANCE 8/10
Brilliant for what I needed but limited for trailers weighing more than 3000kg
HITCHING UP 9/10
Excellent pre-departure checklist and camera make this a great newbie or solo hitch-up
CREATURE COMFORTS 8/10
The seats are not as good as a LandCruiser Prado but for the rest it’s as good as it gets
ACCESSIBILITY OF SPARE PARTS 9/10
There wouldn’t be many places more than 500km from a well-stocked dealer
FUEL ECONOMY 7/10
All-terrain tyres chew a bit of fuel but not too much more than a road-bias Everest V6
SOLO PERFORMANCE 10/10
Aforementioned camera and internal checklist make it a breeze. Add on a great built-in brake controller and you can just hook up and go
ENGINE POWER 10/10
It is the best in class — no question
INNOVATION 9/10
Factory-backed offroad-centric vehicles seem to be all the rage, and we are lucky for it
X-FACTOR 9/10
It looks great and goes as well as it looks. Add in rarity and you have a winner
MY25 FORD EVEREST TREMOR SPECS
Length  4914mm (4.9m /16ft)
Width 1954mm (1.95m /6ft 4in)
Height  1904mm (1.9m /6ft 2in)
Wheelbase  2900mm (2.9m /9ft 5in)
Ground clearance (at kerb weight)  255mm (10in)
Wading depth 800mm (2ft 6in)
Approach / Departure angle 32.0 degrees / 26.9 degrees
Kerb weight 2550kg
Payload 690kg
Gross combined mass (GCM) 6350kg
Gross vehicle mass (GVM) 3240kg
Towing capacity  Unbraked: 750kg
Braked: 3500kg
Towball (max) 350kg
Front axle 1530kg
Rear axle 1770kg
DRIVETRAIN
Engine  3.0L V6 Turbo Diesel
Transmission  10-speed automatic
Power  184kW @ 3250rpm
Torque  600Nm @ 1750–2250rpm
GENERAL
Fuel capacity 80L
Suspension Front: Independent double wishbone (Bilstein position-sensitive dampers/shock
absorbers)
Rear: Coil-sprung live axle
Brakes  Ventilated discs
Wheels  17x8in with General Grabber AT3 265/70R17 tyres; 17in steel spare
(General Grabber AT)
Warranty Five years/unlimited kilometres
MY25 Ford Everest Tremor price from $84,900 plus on-road costs
Options fitted to tow-test model:
  • Premium Paint — Command Grey ($750)
  • Tremor Premium Seat Pack ($1200)
  • Touring Pack/Premium Towing Pack ($2900)
    • 360-degree camera
    • Towbar
    • Integrated trailer brake controller
    • Pro Trailer Backup Assist
  • Rough Terrain pack ($3550)
    • Rough Terrain Bar
    • Under vehicle armour
    • Auxiliary switch bank
MY25 Ford Everest Tremor estimated drive away price as shown $97,163
Ford Australia
P: 13 3673
Tow test: 2025 Ford Ranger PHEV Plug-in Hybrid
Ford’s 2026 Ranger Super Duty: Smarter, stronger and built for towing
Tow test: Ford Australia F-150 XLT LWB
