DIY: 3 easy exterior van fixes - Caravan World Australia
Written by: John Hughes
Exposure to the elements can cause various exterior components on your caravan to deteriorate over time. In this feature, the RV Repair Centre takes us through a few simple external repairs the average competent DIYer can take on.
The protector shade that covers the front window on a van has two common component failures. First, is the pair of little stays that hold the protector shade up in the open position. The stays can corrode over time making the locking knob difficult to turn. The solution is to replace the stays as a pair as they are relatively inexpensive parts. If you can use a screwdriver, a drill and a pop rivet gun this job will be in your skillset. The second common component failure is the little plastic latches that keep the shade in the closed position are prone to breaking. This is another inexpensive parts replacement exercise using the same tools above.
The last job on our list is to replace the cover on a roof hatch. These can fail due to UV exposure or hail damage. We have picked the Jensen-style hatch to show you which only requires a Phillips head screwdriver. It should be noted that some other styles of hatches are significantly more complex to replace. The toughest part of this job is to access the roof with a ladder. Every caution should be exercised when using a ladder as it is a common cause of serious fall injury.
Protector shade stay replacement
STEP 1 Prop the protector shade up with a piece of timber
STEP 2 Open the window to enable free access to work on the stays
STEP 3 Locate the screws retaining the protector shade stay to the window frame
STEP 4 Remove the screws retaining the protector shade stay to the window frame
STEP 5 Detach the protector shade stay from the window frame
STEP 6 Drill out the rivets retaining the protector shade stay
STEP 7 Remove the protector shade stay
STEP 8 Clean up the hole using the drill, being careful not to drill right through the frame
STEP 9 Select suitable length and diameter aluminium rivets to secure the new stay
STEP 10 Insert a rivet into the upper section of the new stay, being careful to orient the stay in the correct direction STEP 11 Locate the stay onto the protector shade
STEP 12 Rivet the stay to the protector shade
STEP 13 Screw the stay to the window frame
STEP 14 Ensure the new stay can hold the protector shade up STEP 15 Repeat the process with the stay on the opposite side
Protector shade latch replacement
STEP 1 The protector shade latch is mounted to the edge of the shade STEP 2 Drill out the rivets retaining the latch
STEP 3 Remove the latch
STEP 4 Source a replacement latch
STEP 5 Use a pop rivet gun suitable for accessing recesses
STEP 6 Rivet the latch to the protector shade — do the slotted hole first
STEP 7 Close the protector and engage the opposing latch
STEP 8 Slide the new latch sideways slightly until it is able to engage
STEP 9 Make a pencil mark to indicate the correct position
STEP 10 Secure the second rivet
STEP 11 The lower part of the latch rarely fails but can be replaced, if necessary, by removing two screws
Hatch cover replacement
STEP 1 Open the roof hatch to gain access to the roof hatch cover screws STEP 2 The roof hatch cover is retained with two screws
STEP 3 Remove the screws
STEP 4 Pivot the roof hatch cover up away from the winder mechanism metal brace STEP 5 Lower the hatch cover at the pivot point to disengage the hinge
STEP 6 Remove the roof hatch cover
STEP 7 Source a replacement hatch cover (we reuse the existing metal brace)
STEP 8 Remove the two screws retaining the metal brace to the new roof hatch cover
STEP 9 Remove the metal brace
STEP 10 Engage the new hatch cover hinge
STEP 11 Insert the metal brace tab into the roof hatch cover slot STEP 12 The metal slot should protrude into the hatch cover as pictured
STEP 13 Pivot the hatch cover down to align with the holes on the metal brace STEP 14 Secure the roof hatch cover to the metal brace with two screws
STEP 15 Wind down the hatch cover
Improper maintenance can lead to injury, death or property damage. Maintenance work of this nature should only be undertaken by people with suitable competence. The information provided is general in nature, not comprehensive and should only be taken as a guide. Individual discretion must be exercised and persons undertaking described tasks do so completely at their own risk. Publishers and creators of this content accept no responsibility for loss or damage. Thanks to Andrew Phillips and the team from the RV Repair Centre, 120 Canterbury Road, Bayswater North Vic 3153, P: 03 9761 4189.
DIY: How to clean fresh and grey water tanks
DIY: How to repair a Cruisemaster DO35 hitch
