RV ducted vacuum
The interVac Central Vacuum System is a ducted vacuum cleaner kit suitable for many RVs. The central unit, which measures 41.5x20.8x10cm, can be built into your van.
The interVac harnesses up to 1300W (240V supply) for suction which is similar to many domestic units, and uses a HEPA filter to minimise dust.
Two types are available: a non-ducted model (CM), which receives the hose in the unit’s front, or a ducted option (RM, pictured) that pipes to outlets inside the van. Both types include a flexible hose that stretches to 10.5m, a floor tool, ratchet wand, crevice tool, dusting brush and upholstery tools. If it’s not surface- or flush-mounted, the CM model can be moved and used in the home as well.
The interVac is manufactured in the USA, designed in Germany and is backed by a conditional five-year RV use warranty. Kits start from $550 for the CM model or $650 for the RM.
For more information, phone (07) 3245 1452 or go to www.cleanerliving.com.au; dealer enquiries are welcome.
