GEAR: HONDA EU30IU HANDY
With a 38kg dry weight, built-in wheels, two fixed handles and a folding handle, the new EU30iu Handy is the lightest and most portable 3000W generator (2600W rated) that Honda has ever made.
Its high-speed, multi-point alternator is integrated into the engine itself, reducing the overall weight and size by 25-50 per cent compared to similarly classed conventional models.
Meanwhile an Eco-throttle adjusts the engine speed to meet the load demand, which saves on fuel so you get up to seven hours’ run time on a full tank of ULP. It also keeps noise levels down – Honda claims it’s the quietest generator in its market segment, producing 56-65dB.
A microcomputer-controlled sinewave inverter caters for frequency-sensitive electrical equipment such as computers.
It also supplies 12V DC at 8A.
The $2999 Handy can be connected in parallel through a built-in connection port so that you can link two EU30iu Handy generators to double the output to 6000W maximum (5200W rated).
For more information on Honda power equipment and your nearest retailer, visit www.hondampe.com.au
