Caravan components: Doorsteps
Tecno Electric Doorstep
This electric step is operated by a switch and has a maximum load weight of 150kg.
The clearance required is 170mm deep when closed. And the closed step is 50mm proud of the mounted flange while the open step is 300mm proud of the mounted flange.
It’s available in single or double step.
- RRP: $550
- Warranty: 12 months
- Dimensions: 560x210mm
- Weight: 5.5kg
- Colours: Silver
- Materials: Aluminium/steel
Features
- Operated by a switch
- Maximum load weight – 150kg
Ranger RV Supplies Doorsteps
Ranger has single/double aluminium manual steps and single/double aluminium electric steps.
- RRP: $140.25 (single manual step); $328.35 (double manual step); $245.85 (single electric step); $575.85 (double electric step)
- Dimensions: Single: 540mm (width), 210mm (drop height); Double: 540mm (width), 300mm (drop height)
- Weight: 5.9kg (single manual step); 6.9kg (single electric step); 7.7kg (double manual step); 8.7kg (double electric step)
- Colours: Silver
Features
- Light and sturdy
- Easy installation
Dometic RV Milenco MGI Double Doorstep
The Milenco MGI double step ensures a safe entry and exit from recreational vehicles every time.
The Milenco MGI will provide you with peace of mind, knowing that your family and friends will have a safe way to enter and exit your recreational vehicle. Built from durable plastics, the Milenco MGI is built for long-lasting and reliable performance.
- RRP: $84
- Dimensions: 620x530x370mm
- Weight: 2.9kg
- Colours: Black
- Materials: 100 per cent recycled plastic
Features
- Safe entry and exit
- 100 per cent recycled plastic, environmentally friendly
- Safely carries a load of 200kg
- Long-lasting and reliable performance
Camec Portable Doorstep
This easily stored aluminium portable step is extremely strong, with foldable legs.
- RRP: $79.95
- Dimensions: 450x350x185mm
- Weight: Approx. 2kg
- Colours: Grey
Features
- Strength
- Easy storage
- Foldable legs
Coast To Coast Fiamma Large Plastic Doorstep Platinum Magnum
The Platinum Magnum is made from UV-resistant HD polyethylene for great stability and strength. The base of the legs can also be pegged into the ground for extra stability. This large plastic doorstep is grey in colour and can hold up to 200kg.
- RRP: $249.95
- Dimensions: 400x580x40mm
- Weight: 1.3kg
- Colours: Grey
- Materials: Polyethylene
Features
- UV-resistant
- Stable and strong
- 200kg weight capacity
The full feature appeared in Caravan World #566. Subscribe today for the latest caravan reviews and news every month!
