Your caravan dental kit and what to do when the nearest dentist is hours away
Your caravan dental kit and what to do when the nearest dentist is hours away - Caravan World
Dental Care on the Road
A broken tooth is a nuisance in the city. On a corrugated road 300 kilometres from the next town, it can change the whole trip. The good news is that most dental problems on the road can be managed until you reach help, as long as you pack a few basics and know which problems can't wait.
At Pure Dentistry in Brisbane, we provide emergency dental care. We reviewed more than 100,000 of our own treatment records from 2015 to 2026. The most common dental emergencies were tooth pain, facial swelling from infection, and chipped or broken teeth. Cracked teeth, knocked-out teeth, wisdom tooth flare-ups and lost fillings or crowns followed. None of them cares whether you're at home or halfway across the Nullarbor.
Generator
Key takeaways
  • Book a check-up a month or two before a long trip, so there's time to fix small problems.
  • Pack long-life milk, gauze, pain relief, temporary filling material and dental wax.
  • If an adult tooth is knocked out, put it back or keep it in milk, and get to a dentist fast.
  • Swelling with a fever, trouble swallowing or trouble breathing needs urgent care.
Be ready for the unexpected on every trip with a first aid kit from Survival Emergency Solutions. Whether you’re touring remote roads, setting up at the campsite or enjoying a weekend away, a well-stocked kit helps you handle minor injuries and everyday mishaps. Explore our range and find one to suit your next adventure.
Before you go, book a check-up
The easiest dental emergency to handle on the road is the one that never happens. Book a check-up a month or two before a long trip, so there's time for any fillings or other treatment. Tell your dentist how long you'll be away and where you're heading.
A tooth that has been a bit sensitive for months, a cracked filling or a wisdom tooth that flares up now and then are all worth sorting out while you're still close to home. If you wear dentures, have them checked too, and pack your old set as a spare if you still have it.
What to pack in your dental kit
Everything below fits in a zip-lock bag in the first aid box.
  • A small container with a lid, plus a few portions of long-life milk. HealthyWA suggests keeping long-life milk in your first aid kit for knocked-out teeth.
  • Sterile gauze or a clean cloth to bite on if a tooth or gum is bleeding.
  • Pain relief you can normally take, such as paracetamol or ibuprofen. Follow the label, and check with your pharmacist or doctor if you have health conditions or take other medicines.
  • Temporary filling material or dental cement from the pharmacy, for a lost filling or crown.
  • Orthodontic wax to cover a sharp edge on a broken tooth.
  • A reusable cold pack for swelling.
  • Dental floss, a spare soft toothbrush and a small mirror.
Knocked-out tooth? Act within 30 minutes
This is the dental emergency where time matters most. The Australian Dental Association advises trying to see a dentist within 30 minutes if an adult tooth is knocked out. When a baby tooth is knocked out, paediatric dentists advise against putting it back into the socket. When the nearest dentist is hours away, what you do in the first few minutes matters even more.
  • Find the tooth and pick it up by the crown, the white part you normally see. Don't touch the root.
  • If it's dirty, rinse it briefly in milk or saline. Don't scrub it.
  • Gently push it back into the socket the right way around, then bite softly on a clean cloth to hold it in place.
  • If you can't put it back, keep it covered in milk, or in the person's mouth between the cheek and gum. Don't store it in water or wrap it dry in a tissue.
  • Head for the nearest dentist straight away, and have someone phone ahead if you can.
  • Baby teeth are different. Don't put a knocked-out baby tooth back in, as it can damage the adult tooth underneath. Keep it in milk and take your grandchild to a dentist.
Generator
Chipped or broken teeth
Corrugations, a hard bit of jerky or a slip on the van steps can all do it. In our records, the two upper front teeth chip more often than any others.
If you can find the broken piece, keep it in milk and take it with you, as it can sometimes be reattached. Rinse your mouth with warm water, hold a cold pack against your cheek if your lip is swollen, and cover any sharp edge with dental wax.
A small chip can usually wait until the next town with a dentist. If the tooth is very painful, very loose or pushed out of position, get it seen sooner.
Toothache and swelling, and when it can't wait
A mild toothache can often be managed for a day or two. This Kids’ Dentist in Brisbane suggests pain relief such as paracetamol or ibuprofen, gargling with salt water and resting with your head propped up on a pillow. Don't hold an aspirin against the gum, as it can burn the tissue.
Swelling is a different matter. Facial swelling from infection was the second most common emergency in our records, and it often involves the back teeth or wisdom teeth. Healthdirect advises seeing a dentist if a toothache comes with a fever over 38°C, trouble swallowing, or swelling in your cheek or jaw.
Get emergency medical care by calling triple zero (000) or going to the nearest hospital if swelling affects your breathing or speaking, or spreads around your eye or neck. Don't wait for the next big town. In remote areas, the local hospital or health clinic is often the best first stop, even if they can't do dental treatment themselves.
Lost fillings and crowns
These are rarely dangerous, but the exposed tooth can be sensitive and may break further. Temporary filling material from a pharmacy can protect it until you're seen. If a crown comes off, keep it safe in a container and take it with you. Don't glue it back with household glue.
Finding a dentist on the road
Save healthdirect's number, 1800 022 222, before you leave. It's a free health advice line that runs 24 hours a day, and its online Service Finder lists dentists, pharmacies and hospitals by location. The Australian Dental Association's Find-a-dentist search is another option.
When you call a practice, say it's an emergency and describe what happened. Many practices keep time aside for urgent cases. If you're heading somewhere very remote, note down the nearest larger towns along your route before you lose phone reception.
A few minutes of planning and a small bag in the first aid box won't stop every dental problem. But it can be the difference between a minor detour and a cancelled trip.
When you’re travelling, knowing what’s nearby can make all the difference. Use Hema Maps to find towns, hospitals and other emergency services along the way, helping you plan your route and travel with greater confidence. Take Hema Maps on your next adventure and stay better connected to the places that matter.
Generator
About the Author
Dr Matthew Peyravi, B.Sc Spec., Hons (T.O), BDentHSc, M.Dent (QLD), is a general dentist at Pure Dentistry in Upper Mount Gravatt, Brisbane, a practice open seven days a week. This article is general information and does not replace advice from your own dentist or doctor. Practice figures come from a de-identified review of Pure Dentistry's treatment records from 2015 to 2026.
