Caravan Tyre Care: Checks to Make Before You Travel
Caravan Tyre Care
Caravan tyres work hard. They carry a heavy load, spend long periods exposed to the sun and can face heat, rain, gravel and corrugations on the same trip. Because they’re behind the tow vehicle, a problem can be easy to miss until it affects how the van travels.
A few simple checks before departure - and regular checks on the road - can help you spot damage early and avoid an unexpected stop. Here’s what to look for when checking your caravan tyres.
💡 Did you know
A caravan tyre blowout can do more than leave you stranded. Flying tyre debris can damage the van’s bodywork, chassis and suspension - so checking your tyres before you travel really matters.
Check tyre pressures when they’re cold
Check your caravan tyres before you set off, while they’re cold. Driving heats them up and changes their pressure, so a reading taken after a long drive won’t give you the same starting point.
Use a reliable pressure gauge and follow the pressure recommended for your caravan and tyre setup. Check the caravan’s manual or compliance information, and ask the caravan or tyre manufacturer if you’re unsure. Don’t assume the maximum pressure printed on the tyre sidewall is the correct pressure for your loaded van.
Check every tyre, including the spare. If you adjust pressures for a particular surface, such as sand or corrugations, follow suitable advice for your van and tyres, and return to the recommended road pressure before travelling on sealed roads.
A tyre pressure monitoring system (TPMS) can provide extra visibility while you’re driving. It tracks pressure and, depending on the system, temperature too. A TPMS is useful for spotting changes you may not notice from the driver’s seat, but it doesn’t replace checking the tyres, wheels and spares yourself.
🚙 For added peace of mind on the road, the Oricom TPS10-6E Tyre Pressure Monitoring System keeps pressure and temperature readings visible in real time. It includes six external sensors and can support up to 10 sensors, making it a practical option for monitoring your tow vehicle and caravan from one solar-powered display. Visual and audio alerts help bring potential pressure changes to your attention while you travel.
Inspect the tread and sidewalls
Walk around the caravan and look closely at every tyre. Check the tread and both visible sidewalls for cuts, cracks, bulges, exposed cords or objects lodged in the rubber. Remove loose stones from the tread and check for anything that could indicate a puncture.
Look across the tread for uneven wear. If one edge is wearing faster than the other, or the wear looks patchy, have the tyres and running gear inspected by a qualified professional. Uneven wear can point to an alignment, suspension or other mechanical issue.
Check tread depth, too. Tyres must meet the legal requirements where you’re travelling, but the legal minimum isn’t a good target for a long trip. If the tread is getting low, ask a tyre professional whether it’s suitable for your planned route and conditions.
Check tyre age, not just tread
A tyre can look acceptable and still have deteriorated with age, especially if it has spent years in the sun or sat unused for long periods. Look for fine cracks in the sidewalls and other signs of ageing. If you spot damage—or you’re unsure about a tyre’s condition—have it assessed before towing.
You can usually find a tyre’s manufacturing date in the code on its sidewall. If the tyres are several years old, ask a tyre specialist or the caravan manufacturer for guidance on whether they should be replaced. There isn’t one replacement age that suits every tyre and use case, so consider the tyre’s condition, storage, distance travelled and the advice for your specific setup.
Don’t forget the spare
The spare tyre is easy to overlook because it may not have touched the road in months. Check its pressure, tread and sidewalls just like the tyres fitted to the caravan. Make sure it’s securely mounted and that you can access it when needed.
Before leaving home, check that you have the right wheel brace for your caravan’s wheel nuts. If you’re not confident changing a wheel, find out how to do it safely or arrange roadside assistance that covers your caravan.
Make checks part of the trip
Tyre care shouldn’t stop once you leave the driveway. Make a habit of checking the tyres before each day’s travel, particularly after the caravan has been parked for a while. At rest stops, take a quick look around the van for visible damage or a tyre that appears to be losing pressure.
If a tyre looks unusually hot, damaged or visibly low, don’t keep driving to see what happens. Find a safe place to stop and investigate. If you’re unsure whether it’s safe to continue, contact roadside assistance or a tyre professional.
A TPMS can help you monitor changes while travelling, but treat an alert as a prompt to stop somewhere safe and check what’s happening. Don’t rely on the system alone to diagnose the cause.
Carry the right roadside gear
A small tyre kit can make a roadside problem easier to manage. Consider carrying:
- A reliable tyre pressure gauge
- A wheel brace that fits your caravan
- A suitable compressor
- A spare tyre in good condition
- A tyre repair kit suited to your tyres, if you know how to use it
- A torch and gloves
A puncture repair kit may help with some tubeless tyre punctures, but it isn’t a fix for every kind of damage. Have a repaired tyre checked by a tyre professional as soon as practical, and don’t attempt a repair if the location or conditions make it unsafe.
If you travel with others, a UHF radio can help you communicate between vehicles when mobile reception is limited - for example, to let the group know you’re stopping to check a tyre. Use it as a communication tool, not a substitute for safe stopping practices or emergency assistance.
Give stored caravans a fresh inspection
If your caravan has been parked for a season, give the tyres a careful inspection before the first trip. Sun exposure, low pressure and long periods in one position can all affect tyres while the van is stationary. Check the tyres thoroughly, including the spare, and top up pressures while they’re cold.
If the van has been stored for a long time, or you notice cracking, flat spots, bulges or other damage, seek professional advice before towing. A quick check at home is much easier than discovering a problem on the roadside.
A simple habit for safer towing
Before each trip, check pressures while cold, inspect the tread and sidewalls, confirm the spare is ready and make sure you have the right tools. Repeat a quick visual check during longer journeys and take any unexpected change seriously.
These checks take only a few minutes, but they can help you catch problems before they disrupt your trip. When a tyre looks damaged, worn or past its best, ask a qualified tyre professional for advice before you tow.
