Beginner Caravanning Guide - What To Do When You’re Starting Out
The beginner’s guide to caravanning in Australia
A caravan gives you the freedom to travel at your own pace, stay close to nature and take many of the comforts of home with you. Getting started does involve some planning, though. You’ll need to choose a setup that suits your trips, understand what your vehicle can tow, learn how to set up safely and get comfortable driving with a caravan behind you.
You don’t need to know everything before your first trip. Start with the basics, practise close to home and build your experience as you go.
Table of contents
Choose the right caravan for your travel plans
Before comparing layouts and features, think about the kind of trips you want to take. Will you mostly stay in caravan parks, or do you want to camp away from facilities? Are you planning weekend getaways, longer regional trips or an extended lap of Australia? Will you travel as a couple, with children, or with pets?
Your answers can help narrow down the type of RV to consider. An on-road caravan may suit sealed roads and caravan park stays. A hybrid camper or off-road caravan may be better suited to rougher routes, while a camper trailer can offer a smaller, lighter alternative. Motorhomes and campervans are other options if you prefer your accommodation and vehicle in one.
Make a list of the features you’ll use regularly. Think about sleeping arrangements, storage, cooking facilities, heating and cooling, bathroom needs, water capacity and power. A larger van may feel more comfortable at camp, but it can also be heavier, harder to manoeuvre and more demanding to tow.
If you’re buying second-hand, check the condition of the chassis, suspension, tyres, brakes, water system and appliances. Look for signs of leaks or water damage, and ask for service and repair records. If you’re unsure what to look for, consider arranging an independent inspection.
Match the caravan to your tow vehicle
A caravan’s advertised towing capacity isn’t the only figure to check. Your vehicle, towbar, coupling, tyres and caravan all have their own weight ratings, and the loaded combination needs to stay within the applicable limits. Check the ratings for:
- Gross Vehicle Mass (GVM): the maximum loaded weight of the tow vehicle.
- Gross Combination Mass (GCM): the maximum combined weight of the loaded vehicle and caravan.
- Maximum towing capacity: the maximum trailer weight the vehicle is rated to tow.
- Towball download: the downward weight the caravan places on the towball.
- Aggregate Trailer Mass (ATM) and Gross Trailer Mass (GTM): the caravan’s relevant loaded weight limits.
Check the owner’s manuals and compliance plates for both the tow vehicle and caravan. Allow for passengers, fuel, accessories, water, luggage and anything else carried in the vehicle or van. A setup that appears suitable on paper can exceed a limit once fully loaded. The National Heavy Vehicle Regulator (NHVR) advises that manufacturer ratings must be observed; the applicable limit can depend on the vehicle and its components. If you’re uncertain, speak with a qualified professional and consider having the loaded rig weighed.
Weight also needs to be distributed carefully. Secure your belongings so they can’t shift during travel, and follow the caravan and vehicle manufacturers’ guidance on loading. Don’t assume you can fix poor weight distribution by changing how you drive.
Start with the accessories you’ll actually use
A new caravan may already include some equipment, such as cooking facilities, a hot-water system or storage. Before buying extra accessories, spend time with the van and work out what’s missing for the way you travel.
Start with practical essentials: suitable power and water connections for your destinations, wheel chocks, a first-aid kit, basic tools, a torch, and items to keep your campsite clean and comfortable. If you’re travelling with children or pets, plan for their needs too.
It can be tempting to buy every recommended gadget before leaving home. Try a short trip first and note what you used, what you missed and what stayed packed away. That gives you a more useful shopping list for your next adventure.
Pre-owned items such as camp chairs, crockery and storage can be good value. For electrical or safety-related equipment, check its age, condition and compatibility before relying on it. A qualified inspection may help you decide whether an item is suitable.
Cgear Camping Mats
A comfortable, tidy campsite starts with a good base. Cgear Camping Mats help keep dirt and sand from being tracked through your setup, while adding a practical surface for relaxing outside. They’re a useful first accessory for new campers and caravanners who want to make camp feel cleaner and more comfortable.
Plan your first trip close to home
For your first outing, choose a destination that’s within a comfortable drive and has the facilities you need. A powered site in a caravan park can make it easier to get familiar with your van’s systems, while a nearby campground gives you room to practise setting up without the pressure of a long itinerary.
Check booking requirements, arrival times, site access and any restrictions before you leave. Think about whether you’ll need to bring drinking water, arrange a dump point stop or book a powered site. Check the weather and road conditions, and allow extra time for breaks and slower travel.
Make a checklist for departure and arrival. Before leaving, check your tyres, lights, mirrors, coupling, safety chains, brakes and load restraints. Confirm that cupboards and external hatches are closed and secured. When you stop during a trip, take a moment to check that everything still looks right before continuing.
Practicing Levelling Your Caravan
Arriving at a campsite is easier when you have a simple setup routine. Choose a suitable spot, check for overhead branches and soft ground, and make sure you have enough room to manoeuvre. If you’re staying in a caravan park and need help reversing into a site, ask the manager or another staff member for guidance.
Once positioned, level the caravan according to the manufacturer’s instructions. Use levelling ramps or blocks designed for the job, and secure the wheels with appropriate chocks before unhitching. Levelling aids help bring the caravan to a more even position; they are not a substitute for the caravan’s stabiliser legs or wheel chocks.
Tred GT Levelling Kits
If your entry-level caravan or trailer doesn’t have built-in levelling equipment, TRED GT Levelling Kits offer a straightforward, budget-friendly way to help get set up at camp. They’re a practical starting point for new owners who want to level their van on uneven sites without overcomplicating their kit.
Tow safely and build confidence gradually
Towing changes how your vehicle accelerates, brakes, turns and responds to wind and road surfaces. If you haven’t towed before, consider professional training or a supervised practice session before heading away. Practise turning, braking, reversing and parking in a quiet, open area.
Before driving, make sure the caravan is correctly coupled and that safety chains, electrical connections and breakaway equipment are attached as required. Set your mirrors so you can see along both sides of the caravan, and check your lights and brakes are working. Transport Victoria’s caravan guidance also recommends pre-trip checks and careful preparation before setting off.
Leave plenty of space between your rig and the vehicle ahead, and increase your following distance in wet weather, on loose surfaces or when visibility is poor. Brake progressively and take corners wide enough to keep the caravan’s wheels clear of kerbs and roadside hazards. Follow posted speed limits and adjust your speed to suit the road, traffic, weather and conditions. Your vehicle or caravan manufacturer may set additional limits.
Reversing is often the manoeuvre beginners find most challenging. If possible, ask a spotter to guide you from a position where they can see you and where you can see them. Agree on simple signals before you start, reverse slowly and stop immediately if you lose sight of each other. There’s no need to rush; getting out to check your position is part of the process.
The Towing Glovebox Guide by Robert Pepper
New to towing? The Towing Glovebox Guide by Robert Pepper is a handy introduction to towing basics, with clear explanations and illustrations to help make the learning curve easier to follow. Keep it close as a reference while you build confidence on the road.
Be a considerate caravanner
Caravan parks and campgrounds bring travellers close together, so a little courtesy makes a difference. Keep music and conversations at a considerate volume, respect quiet hours, give neighbouring sites space and follow the park’s directions for parking, rubbish and shared facilities. If you’re travelling with a dog, check the site’s pet rules and keep your pet under control.
On the road, allow other drivers room to pass when it is safe and legal to do so. Use designated stopping areas to let traffic through rather than pulling over somewhere unsuitable. A UHF CB radio can be useful for communication in some situations, but don’t assume every driver is monitoring the same channel. The ACMA lists UHF channels 5 and 35 as emergency channels; check current guidance and use your radio responsibly.
If you stop because of a breakdown, move as far from traffic as you safely can and follow the relevant road authority’s advice for the location. Carry a high-visibility vest and warning equipment if appropriate, but only place it where it’s safe to do so. If you see another traveller in trouble, offer help only when you can do so safely.
Keep learning as you travel
Your first trip is a chance to learn what works for you. Keep notes about your setup, packing and route, then make small changes before the next outing. Over time, you’ll get quicker at hitching up, setting up camp and planning what to bring.
Caravanning is a practical skill as much as a way to travel. Start with a suitable vehicle and van, check your weights, take your time and choose trips that match your experience. With preparation and practice, you can build confidence and enjoy more of the places Australia has to offer.
The next step
If you’re choosing your first RV or considering an upgrade, explore the latest listings and advice at TradeRVs. Speak with sellers about the features, condition and suitability of any van you’re considering, and verify the weights against your tow vehicle before you buy.
Frequently Asked Questions
What should I know before buying my first caravan?
Decide how you plan to travel, who’s coming with you and where you’ll camp. Then check that your tow vehicle can safely handle the caravan’s loaded weight.
How do I know if my car can tow a caravan?
Check the ratings in your vehicle and caravan manuals, including towing capacity, GVM, GCM, ATM, GTM and towball download. Account for passengers, water, accessories and luggage, and have the loaded rig weighed if you’re unsure.
Do I need towing lessons before my first trip?
Lessons aren’t compulsory everywhere, but they can help you practise braking, reversing, turning and other towing skills in a safe setting
What should I take on my first caravan trip?
Start with essentials such as wheel chocks, suitable power and water connections, basic tools, a first-aid kit, a torch and items for a clean, comfortable campsite. A short trial trip can help you identify anything else you need.
How do I level a caravan at a campsite?
Follow the caravan manufacturer’s instructions and use suitable levelling ramps or blocks. Secure the wheels with chocks before unhitching; levelling aids don’t replace wheel chocks or stabiliser legs.
Are caravan towing rules the same across Australia?
Road rules and requirements can vary by state and territory. Check the relevant road authority’s current guidance, as well as your vehicle and caravan manuals, before travelling.
