Father's Day Gift Guide
Father's Day Gift Guide - Caravan World Australia
SCOOTER HUT ELECTRIC SCOOTERS
Electric scooters have seen huge growth over the last 12 months and have the potential to slash congestion and pollution in cities. Not to be confused with rental scooters seen in major cities, these private electric scooters will allow you or your father an easy, convenient, and most importantly, fun mode of transportation without breaking a sweat.
These scooters range from lightweight and foldable for the everyday commuter, to larger, high-performance models with offroad capability, perfect for the next caravanning trip. Battery size determines the distance a scooter can travel, with maximum range starting at 25km, all the way to 150km in the higher end models.
Scooter Hut stocks a large range of electric scooters for all riders and for your ease of mind, they have expert technicians in all their stores to help you choose the correct model for your father.
MORE INFO
E-GLIDE D150
RRP $999
W scooterhut.com.au/e-glide-d150-electric-scooter/
E-GLIDE MACH10
RRP $2299
W scooterhut.com.au/e-glide-mach-10-electric-scooter/
KAABO WOLF WARRIOR 11+
RRP $4499
W scooterhut.com.au/kaabo-electric-scooter-wolf-warrior-11/
KAABO MANTIS 10 SOLO PLUS
RRP $1999
W scooterhut.com.au/kaabo-mantis-10-solo-plus-electric-scooter/
THIRSTY NOMAD WATER FILTER
Thinking of a water filter? A good one should be designed and performance tested by water scientists. It should kill bacteria and viruses upon contact, contain 0.001 micron Ultrafiltration, meet NSF 61 and 42 Standards, meet the NSF Protocol 231 for bacterial elimination and have been independently tested by certified laboratories.
The Thirsty Nomad’s 5 in 1 water filter turns river or creek water into clear, safe drinking water, otherwise it’s a 100 per cent money back guarantee.
MORE INFO
RRP $219.95
W thethirstynomad.com.au
HEMA HX-2 NAVIGATOR
Give your father the chance to explore somewhere new with Hema’s new HX-2 Navigator, the ultimate GPS system for on and offroad navigation. With updated topographic mapping, turn-by-turn navigation and new and updated campsites, caravan parks and other touring points of interest, the HX-2 will be a constant companion on your dad’s future trips.
MORE INFO
RRP $749
A screengrab of the Navigator in use
ITECHWORLD
Everyone has their favourite toys and must-have devices when caravanning so this father's day, make sure your father or father figure has plenty of power to run his technology with from iTechworld.
iTechworld’s batteries start with the iTECH100A. The 100A of high-performance usable DC power, coupled with the Redback Lithium Operating System ensures these lithium batteries will outperform and outlast its rivals.
On the generation side of things, a solar blanket is the perfect mobile solution for charging anything in your caravan or campsite, and portable enough to come with you even further afield. iTechworld’s 200W solar blanket kit is shade tolerant, compact, and can tolerate temperatures as cold as -40 degrees, up to as hot at 85 degrees.
MORE INFO
iTECH100A
RRP $780
W itechworld.com.au
200 Watt Solar Blanket Kit
RRP $499
W itechworld.com.au
An iTechworld battery in the current range
HEMA GREAT DESERT TRACKS MAP
Hema’s Great Desert Tracks Map Pack will allow your dad to explore the arid centre with comprehensive maps that traverse Australia’s desert regions. Each map is tear proof, waterproof and field checked and comes in a soft and durable map wallet. The Pack is perfect to navigate every desert track and journey throughout Australia.
MORE INFO
RRP $99
W shop.hemamaps.com/products/hema-great-desert-tracks-map-pack
THE VICTORIAN HIGH COUNTRY MAP PACK
This map pack presents Hema’s iconic The Victorian High Country series in a soft and durable wallet. Explore Victoria’s 4WD mecca with these four comprehensive maps that traverse one of Australia’s most diverse mountainous regions. Each map is waterproof, tear proof and field-checked by the Hema Map Patrol to ensure the accuracy and detail for travel in this area.
RRP $54.95
W shop.hemamaps.com/products/the-victorian-high-country-map-pack
4WD ADVENTURES PLANNER PACK
Get your father inspired to experience Australia’s wide-open spaces with Hema’s 4WD Adventure Planner Pack. The pack contains everything your father needs to plan and prepare for his next caravanning adventure, making it easy to discover tracks and destinations along his chosen path. Includes the 4WD Adventure Guidebook, a Go-to-Guide for 4WDs and a Where to Camp Guidebook.
MORE INFO
RRP $129.95
W shop.hemamaps.com/collections/specials/products/4wd-adventure-planner-pack
